Bespoke Events using SendKey/SendKey* P3d V4
I am not able to get Bespoke Events using SendKey to work. (Firing the event has no effect)
I am trying to set up keypress combinations to select different cameras views (pre release version of ChasePlane). I have tried both SendKey & SendKey* on 2 different aircraft. I am using P3d V4 + hotfix with 64bit GFiT everything else seems to work ok. For completeness I was trying to select ChasePlane cameras using Shift+T & Shift+R key combinations.
This works ok using FSUIPC5 on non GoFlight devices. FSUIPC5 does not yet support GoFlight hardware
Musky2015
    You need to run GIT As Administrator for that task type to work.
    Task is still not working even with GIT being run as Administrator, I am going to uninstall and reinstall and restore config files and will let you know if issue is still there after clean install
    Mark
    Musky2015
  • Hi Mark,
    I have both GIT and P3D running as admin.
    As a matter of course I normally run everything P3D related as Administrator I had just overlooked it after installing GIT. I have checked and both GIT & P3D are running as Administrator, but the event does not run
    Mark
    Musky2015
  • I tested it with the pause command (Send P). Does that work?
    I have found that this problem is isolated to key assignments set up in ChasePlane.
    Sending "P" works OK and other keypress combination are working when they are controlling aircraft switches. Its only a problem when trying to select a ChasePlane camera. Again I made sure ChasePlane, P3D & GIT were running under Administrator.
    This issue not a big deal for me
    Many thanks
    Mark
    Musky2015
