Cannot get TQ6 to work proprrly
Dear Steve & others
Im struggling with my TQ6 and fsx (with Windows 7). I have the latest GIT version installed, but i just cannot get the spoilers or throttles to work. With fsuipc they work almost fine, but when i unassign all axes from fsuipc i cannot get the levers to move just using GIT assignments or they move erratically. When i move the levers (during assignments) the numbers move correctly on GIT but it does not make the levers move in fsx.
Im sure there has to be some conflicts but i dont know which could cause it as no keys are assigned to throttles or spoilers and fsuipc is clear as well as goflight own assignments are clear.
I would need assistance on this matter, im even willing to pay for it to make things work.
Thanks in advance
Best regards
Thomas Schmiedeke
Thanks in advance
Best regards
Thomas Schmiedeke
Have you followed these steps: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/19-operating/25-configuring-joystick-devices.html
Yep, exactly the quide i was followong, sorry if i was not clear enough for my original post.
Cheers
Thomas
Is this what you were looking for?
Cheers
Thomas
If that doesn't solve the problem, let me know what aircraft you are trying it with and I will attempt to replicate the issue.
Thanks for your input. Goflight throttle is disabled from fsx settings, I have not tried yet to disable fsuipc and not quite sure how to do it, but I think I can find that information myself...
Anyway, im having this issue with the PMDG T7 and also 747 QOTS II.. Not tried it yet with the 737 NGX...
Cheers
Thomas
PS: Double check GFConfig and make sure you haven't assigned anything to the axes in there. Remember there can be up to 3 different tabs where the LGT can be configured, each one for a different flight sim version if you have them all installed.
Did some tweaking and finally got the throttles to work properly and after disabling fsuipc, my spoilers started to work. So once problem solved, few more to go...
Thanks so far, finally i get the throttles work as they should
Cheers
Thomas
Any idea how to check the possible dublicates and how to delete ones? As far as what comes to checking directly from FSUIPC, there was nothing assigned... Or would it be best to delete the fsuipc.ini file and let fsx create new from the scratch?
Cheers
Thomas
many many thanks for your support Steve, excellent!
