Why is my MCP Pro adjusting all dialed inputs in increments of threes?
Hi, I have P3D v4, PMDG737NGX, SPADnext, Saitek controllers/radios/switch panel, Throttletek and MCP Pro & EFIS from GoFlight. All finally working together, other than the fact that I can only increase or decrease dialled settings (altitude, course etc..) in the MCP in increments of three.
Any ideas?
    Is it incrementing in 3 in the VC of the NGX as well as the GoFlight MCP or is the VC not changing?
  • Hi Steve, yes, in the VC as well. I can adjust the VC MCP in increments of one which is also reflected in the GoFlight MCP.
  • Is it 3 or 300? If its 300, I suspect PMDG have changed something and I may need to turn off control acceleration in GIT as I did for the 777. If it is 3, then I think a uninstall/reinstall of the NGX would be the best course of action.
  • Believe it or not Steve, the altitude moves in 300's and the others in threes! :-). This was working fine last night by the way, but not this morning.
  • edited July 2017
    OK, can you reboot and try it again. If you loaded up an aircraft that enabled control acceleration it could have carried over to the NGX.
  • Rebooted; same issue. My default aircraft when starting P3D is the Beech King Air 350. I then normally change the aircraft to the PMDG737 before confirming scenario. I read somewhere that the PMDG aircraft should not be set as default. Any suggestions? Change the default perhaps?
  • Let me get a test version over to you in a few minutes. Hang on!
  • I have just PM'd you a link on the forum to a new version of GIT. Let me know asap as I need to get a new release out that fixes other issues as well.
  • Will do Steve - many thanks. In the meantime, I tried to set the PMDG as default just to see if that would work. Now P3D quits loading after a few seconds! Looks like A) that was a bad idea and B) I''ll have to do a fresh install of P3D before I can test your new version. Onto it now!
  • Perhaps your NGX install is messed up then. I would reinstall that as well before trying the test version of GIT as no one else has reported this problem.
  • Will do Steve, I'll let you know.
    Cheers.
  • Answer ✓
    How are you getting on? I could do with an answer ASAP so I can determine whether to include the fix I gave you in Friday's new release.
  • Hi Steve, Apologies, but I've had an overall nightmare that led to a complete reinstall of Windows! Working on it currently and I will hopefully conclude by Sunday latest. I'll update you then.
  • Hi Steve, all back up and running again with everything working nicely! This morning I inadvertently reinstalled the version that I had the issue with originally and lo and behold, it now works fine! The only thing I have left to install is FSUIPC which I need for my Throttletek quadrant. It'll be interesting to see if that screws everything up again!
