New Installation question
Just installed this as I have just bought a GF-46 that I would like to use in XP11.
In the user guide it says For DRE Mimic Mode to work, the DataRef Editor Plugin must be physically removed from X-Plane. Disabling it will not work.
I have looked in the /Resources/Plugins folder and cannot find the plugin anywhere.
I'm I looking in the right place?
Yes, but it won't be there unless you installed it in the first place, so if you cannot see it, don't worry.
FYI, The GF46 alerting service is broken, but I'm about to release a new version that fixes it within 24hrs so keep a look out for it. Normal operation of the GF46 is OK though.
My aim is to set the GF-46 up to handle autopilot information such as heading , Alt etc . Also it seems every time I load up xplane with the GIT running I have to manually go in and select the device and enable it which seems a bit strange
I don't know why but I'm struggling to get the hang of the configuration on the modules.
There seems so many parameters within the list , and some of them are very similar
Could you possibly give me an example of say , setting the GF46 to display autopilot alt (and be able to edit it with the knob) and also maybe setting the first button my P8 to switch on and off the landing Beacon light. Once I see how it's done , I should be ok.
Display Data: sim/cockpit/autopilot/altitude
Rotary Event (Left Knob/Non pushed): CLOCKWISE, sim/autopilot/altitude_up
Rotary Action: ROTATE
Rotary Event (Left Knob/Non pushed): ANTICLOCKWISE, sim/autopilot/altitude_down
