GFIT P3Dv4 Simconnect Exception received: Duplicate_ID
Hello, I have installed GFIT for P3Dv4 vers. 3_0_0_0 since 3_1_0_0 I can not execute (nothing happens after installing as admin...) GF driver 2.28 is installed and started after launing P3Dv4 - GFIT can not connect, red button is showing and log says SimConnect exception received: Duplicate_ID. Driver and GFIT is noted in exe.xml and dll.xml under prepar3D appdata roaming folder. I have installed Active Sky running via network/ simconnect and it is working well. Several attempts to reinstall and configure new, no help at all. A former FSX installation is at the flightsim PC but FSX is not used anymore. Can you help in this matter, please check GFIT P3Dv4 file too, no excecution possible. Best regards
The dll file seems to have got corrupt in the new build. I have rebuilt the download, so if you re-download and install, it should all be OK.
It should be working fine as I recreated your initial problem and now it all works OK at my end. You could try renaming My Documents\GoFlight Interface Tool so you start with clean settings, but it should not be necessary.
15:23:48 GoFlight Connection Starting.....
15:23:48 SimConnect Connection Starting.....
15:23:49 SimConnect Message Processing Started
15:23:49 GoFlight Connection Started
15:23:49 SimConnect Connection Started
15:23:49 Aircraft Connection Starting.....
15:23:49 PMDG SDK option is OK in Prepar3D v4
15:23:49 SimConnect: Event Received: Aircraft Type Changed
15:23:49 SimConnect: Event Received: SIM, 1
15:23:49 SimConnect: Event Received: PAUSE, 0
15:23:49 SimConnect Message Processing Finished
15:23:50 SimConnect Connection Starting.....
15:23:51 SimConnect Message Processing Started
15:23:51 SimConnect Connection Started
15:23:51 Aircraft Connection Starting.....
15:23:51 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
15:23:51 SimConnect: Event Received: SIM, 1
15:23:51 SimConnect: Event Received: PAUSE, 0
15:23:52 Aircraft Connection Starting.....
15:23:52 SimConnect: Exception Received: ERROR
15:23:53 SimConnect: Exception Received: DUPLICATE_ID
Best regards
So with GIT 3.1(fixed version) and the Beech Baron can you get into Detective and turn on Lvar monitoring and do you see a stream of Lvar changes displayed? If not what can you do/see? Can you copy and paste the log.
Cortana and edge stuff is deactivated, I'm using firefox within Windows10. Can you review the installation calls of the GIT 3_1 again since I never have had problems to install a application on my system. At the moment I'm happy to solve the duplicate_ID error but I wish to install the lastest update of GIT too. Best regards and thank you for your excellent support, I aprreciate this.
As for 3.1, if the setup program is not starting, I suspect its a corrupt download or your AV software is intercepting it.
