Upgraded from 2.7 to 3.1.0 Broke my install :(
Hello! So I recently purchased and installed another goflight module - the WP6. As I was configuring it I had issues with the lights so I decided to check for software updates. I installed version 3.1.0.0 for v4 and now none of my modules appear to work. GFIT is flashing green under GoFlight, Solid Yellow under SimConnect and flashing Red for Aircraft (The NGX). Any idea what may have broke? All modules worked fine under version 2.7.
  • I keep getting the following logs that keep repeating:
    21:40:49 SimConnect: Exception Received: ERROR
    21:40:50 SimConnect: Exception Received: DUPLICATE_ID
    21:40:50 Aircraft Connection Starting.....
    21:40:51 SimConnect: Exception Received: ERROR
    21:40:51 SimConnect: Exception Received: DUPLICATE_ID
    21:40:52 Aircraft Connection Starting.....
    21:40:52 SimConnect: Exception Received: ERROR
    21:40:53 SimConnect: Exception Received: DUPLICATE_ID
    21:40:53 Aircraft Connection Starting.....
    21:40:53 SimConnect: Exception Received: ERROR
    21:40:54 SimConnect: Exception Received: DUPLICATE_ID
  • I tried with a default aircraft and all seemed to work. I completed uninstalled GFIT and the Goflight software, reinstalled and now all seems well. Phew!
