MCP Pro - Displays not working.
Hi all, I am a new user of the interface software. I own the GF EFIS, MCP PRO and GF166 radio panel and use P3D V4.
All buttons and switches on my MCP PRO work perfectly with the PMDG NGX, however all displays on the FMC are stuck to their "0" values (course 000, IAS not displaying anything, heading 000, altitude 0, vert spd 00000). What is the problem? Are there any settings I need to change? The EFIS works with no problem btw.
Also, I cannot get the radio panel to work. Displays are off and the buttons do not do anything. All 3 panels I have are detected by the interface tool.
Demetris
Demetris
Go through the steps in the FAQ entry "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes)" found here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/70-faq-goflight-interface-tool.html
1. Installed the lastest GIT yesterday
2. F-22 is default aircraft. Change it to whichever aircraft at the Free Flight Screen.
3. SDK entry was enabled. I even copy pasted yours just in case there was some error in its writing for some reason.
4. All set to Run as Administrator. Although I'm contemplating seeing about running in compatibility mode.
5. .Net Installer says I'm running the latest version.
Any more ideas why this is happening?
