GFIT P3Dv4 Simconnect Exception received: Duplicate_ID
2»
  • Hello Steve, it used the 5th and 6th download and I have no virus program except defender, tried with defender on and off, same result, no installation possible.
    Best regards
  • I'll pm you a download link now.
  • I got it, after setting the hook under the 3_1_0_0 installation exe properties / attributes / file from another pc... allowing installation it finally works. Never have observed this square under attributes before. Now version 3_1_0_0 is working, for the GF-WP-6 I will try something to get it working too. Steve, thanks for your patience in this case, as before I'm a happy customer. Btw can you reset my download counter since it is rapidly decreasing... Best regards
  • Hi
    I too am having similar issues with P3Dv4. I've downloaded & installed the appropriate version of GIT but the light stays yellow & the log keeps saying Duplicate ID. I've tried uninstal/reinstal but nothing!! I really need to get this working, as right now, I have a very expensive piece of hardware doing nothing!!
    Why can't I contact PollyPot by phone??
  • I've just done another reinstall & am now getting this message:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.TypeInitializationException: The type initializer for 'A.' threw an exception. ---> System.IO.FileNotFoundException: Could not load file or assembly 'LockheedMartin.Prepar3D.SimConnect, Version=3.4.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
    at A...cctor()
    --- End of inner exception stack trace ---
    at A..()
    at A..(Object , EventArgs )
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.2102.0 built by: NET47REL1LAST
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    GoFlight Interface Tool P3Dv4
    Assembly Version: 2.747.3.2
    Win32 Version: 2.747.3.2
    CodeBase: file:///C:/Program%20Files%20(x86)/GoFlight/GoFlight%20Interface%20Tool%20P3Dv4.exe
    System
    Win32 Version: 4.7.2103.2 built by: NET47REL1LAST
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    GoFlight Interface Tool P3Dv4&
    Assembly Version: 1.0.0.0
    PresentationFramework
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
    WindowsBase
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
    System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    PresentationCore
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
    System.Xaml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
    System.Configuration
    Win32 Version: 4.7.2046.0 built by: NET47REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    LedControl
    Assembly Version: 0.5.395.0
    Win32 Version: 4.7.2104.0 built by: NET47REL1LAST
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Microsoft.CSharp
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
    ActiveLock3_6Net
    Assembly Version: 3.6.1.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.7.2046.0 built by: NET47REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    PresentationFramework.Aero2
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
    PresentationFramework-SystemXml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
    UIAutomationTypes
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
    UIAutomationProvider
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
    Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    Windows.UI
    Assembly Version: 255.255.255.255
    Win32 Version: 10.0.10011.16384
    CodeBase: file:///C:/WINDOWS/system32/WinMetadata/Windows.UI.winmd
    Windows.Foundation
    CodeBase: file:///C:/WINDOWS/system32/WinMetadata/Windows.Foundation.winmd
    System.Runtime.InteropServices.WindowsRuntime
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.InteropServices.WindowsRuntime/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.InteropServices.WindowsRuntime.dll
    System.Runtime.WindowsRuntime
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.WindowsRuntime/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.WindowsRuntime.dll
    System.Runtime.Serialization
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
    CustomMarshalers
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/CustomMarshalers/v4.0_4.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
    System.Management
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    System.Web
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
    SMDiagnostics
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
    System.ServiceModel.Internals
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll
    Anonymously Hosted DynamicMethods Assembly
    Assembly Version: 0.0.0.0
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
    System.Dynamic
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Dynamic/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Dynamic.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    It is an error stating that it cannot find 'LockheedMartin.Prepar3D.SimConnect.dll'. This file is built into GIT for P3Dv4 but it appears not to be working for you. If you copy this file into the GIT installation directory it should work OK. The file is here: https://www.dropbox.com/s/6yf6u880fi7735f/LockheedMartin.Prepar3D.SimConnect.zip?dl=0
