WP6 - Configuration not saved
Hello,
I use version 3.2.0.0 of GIT (and I am very happy with the iFLY management !).
I have a problem with the configuration of the WP-6 module : I can configure it (for the iFLY 737), but if I exit of FSX and of GIT, and start-up next time both, the WP-6 config configuration is blank. The DIO, the EFIS configs are correct, but I need to re-do the config of the WP-6. (I saved the config, so, I can reload it, but I think it should work like the DIO and the EFIS, without having to load manually a config file).
Did I missed something ?
Thank you for your help.
Jean-Louis Coussot
  • I'll look into and try and get an update out over the weekend if I find a bug.
  • Ok, I have just done a quick test with the iFly 737 and GIT 3.2.0.1 and the WP6 saved and loaded ifly and simconnect info OK.
    Perhaps its the combination of things you have setup in the WP6. Can you attach the config here for me to try.
    Also, do you get an error message?
  • Problem solved : I changed for the last 3.3.0.1 and the problem is nom more here !
    And the new search function is a must ! Really happy with your GIT software !
