GIT Showing out_of_bounds & Connection Failed
Hi Folks
So I've just got my sim back up and running again after a long break from FSX, and having now re-setup SimConnect, I have:
PC-1 = Windows 10, 64bit (P3Dv4 Rig) - FSUIPC5 with WideFS & ASNConnect
PC-2 = Windows 7 32bit (Simconnect rig with GF Hardware plugged into this)- WideFS7, Active Sky P4 for P3Dv4, GFConfig 2.28, Loads of GoFlight kit inc MCP Pro, Efis, TQ6, 4 switch panels, Radio stack etc.
I load up the latest GIT on PC-2, I get 3 green lights, then the SimConnect light goes Yellow, and the log is showing this:
00:16:23 GoFlight Connection Starting.....
00:16:23 SimConnect Connection Starting.....
00:16:24 SimConnect Message Processing Started
00:16:25 GoFlight Connection Started
00:16:25 SimConnect Connection Started
00:16:25 Aircraft Connection Starting.....
00:16:25 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
00:16:25 SimConnect: Event Received: SIM, 1
00:16:25 SimConnect: Event Received: PAUSE, 1
00:16:26 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:28 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
00:16:28 Aircraft Connection Started
00:16:28 Simconnect Version: 3.4.0.0
00:16:28 Synchronising Switches & Selectors .....
00:16:28 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:29 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:30 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:31 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:32 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:33 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:34 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:35 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:36 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:37 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:38 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:39 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:40 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:41 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:42 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:43 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:44 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:45 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:46 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:47 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:48 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:49 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:50 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:51 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:52 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:53 SimConnect: Exception Received: OUT_OF_BOUNDS
00:16:55 Synchronising Switches & Selectors Complete
00:17:04 SimConnect: Event Received: INTERFACE_RESTART, 0
00:17:04 SimConnect Message Processing Finished
00:17:04 GoFlight Connection Starting.....
00:17:05 SimConnect Connection Starting.....
00:17:05 GoFlight Connection Started
00:17:06 SimConnect Message Processing Started
00:17:06 SimConnect Connection Started
00:17:06 Aircraft Connection Starting.....
00:17:06 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
00:17:06 SimConnect: Event Received: SIM, 1
00:17:06 SimConnect: Event Received: PAUSE, 1
00:17:07 SimConnect: Exception Received: OUT_OF_BOUNDS
00:17:09 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
00:17:09 Aircraft Connection Started
00:17:09 Simconnect Version: 3.4.0.0
This is with the A36 Bonanza loaded in P3Dv4..
So I'm trying to work out why GIT is not working, because its not letting my configure any GoFlight kit, nor use any of my GoFlight kit with the Bonanza?
SimConnect must be working, because I can restart GIT right from within P3Dv4, so the 2 computers are talking to each other correctly, so it must be a configuration somewhere that's gone a bit off..
Active Sky is not connecting to the sim either, seems to be stuck on "Waiting for simulator", but that's another days work I'm sure.
Also curious as to why it shows SimConnect v3.4.0.0?
If there is any help, advice you can provide to get this working, I'd really appreciate that :-)
I have Teamviewer, and work from home all day every day.
Best regards
Rich
Best regards
Rich
The OUT OF BOUNDS error means the GoFlight Interface Module 64.dll is not running or responding. Can you verify its present in dll.xml
I looked in "C:\Program Files (x86)\GoFlight" but there is no file of that name.
However, I searched in C:\Users\rich\AppData\Roaming\Lockheed Martin and found one there.
Opened it in Notepad and see that when the GIT is installed on my main PC, the one that has P3D on it, this DOES have this:
GoFlight Module Interface
False
C:\Program Files (x86)\GoFlight\GoFlight Interface Module 64.dll
However, my slave PC, the simconnecting one doesn't have P3D installed, so it seems it doesn't even have an "C:\Users\rich\AppData\Roaming\Lockheed Martin" folder to install that file to?
How can I tell the SimConnecting PC that P3D is on the master PC?
Oddly enough, having now installed GIT on both computers, the slave PC now gives all 3 green lights, no errors, but none of the hardware works on the Carenado Bonanza?
I dont have the 737 installed yet, as I wanted to get the connectivity working and test things with as few addons installed as possible.
With the GF Throttles for example, they are showing as working on the slave PC, but have no affect on the aircraft, regardless of how I try to calibrate :-(
Yet I can still restart GIT from within P3D, so the connectivity is there and working..
Am only going to install P3Dv4 on main RIG and then the GIT and GFConfig on slave computer.
Only when the controls are working, will I move on to Active Sky. Head hurting and eyes blurry now lol..
So, the plot thickens. After re-installing my entire P3Dv4, this time to C:\Sims instead of its normal path, and then re-installing all 4 simconnect modules on both computers, then reinstalling both GFConfig and GIT, I now have no simconnect connectivity at all.
I also don't have any errors either, only this screenshot.
Took things to the extreme, I went through the entire system registry on the client machine to check and fix file paths, no luck there.
WideFS connects perfect, as do the ipads connect to the client-PC, which is running Remote-Flight, that connects over Wide-FS, so that all works, there is connectivity and its perfect, so something is wrong with SimConnect itself.
Cannot get Active Sky to connect either, it just doesn't want to know.
I tested the kit with GIT on the server PC, and its working fine, only had to move 2 USB plugs to do that, so was easy..
I'm stuck then mate. Don't know what to do next.. Am sort of convinced that Simconnect doesn't work on P3Dv4??
I put a notice up in the forum that I was on holiday for 10 days, so hence the late reply.
If I recall Wide-FS does not use Simconnect, so this confirms the issue. What versions of Simconnect have you installed on the client-PC?
So after a bit of a meltdown, and having to refurb the water-cooling, I replaced the slave PC for a new fast one, and set about re-installing Win10 on both, to ensure both PC's match.
Over the last 2 days, I have opted for installing P3Dv3, and NOT v4, as my PC is 6 years old now.
So I almost have everything working, except that when now loading the GIT, the "Simconnect/FSX light stays yellow and the tabs are all greyed out (Still, same as last time)
From within P3D, I can restart GIT, so SimConnect connectivity is there and working.
I took a few screenshots of GIT running on slave PC, whilst sat in the Virtual Cockpit, as per your other tech threads here, that had no affect.
Also downloaded that VC 2013 c++ library, inswtalled, no joy again.
Am kinda stuck now mate.
The last time this all worked, was in FSX, over a year ago, and I'm literally at the point of quitting this hobby having blown a fortune on it and not being able to use the sim, either that or go right back to FSX, but I fear that will no longer work either as I dont have the old versions of GIT that did work... (2.4 something)
From the 4 pictures, you can see the GIT Connectivity, (It works even before I installed FSUIPC+WideFS), the log it creates, the TABS all greyed out whilst sim is live and running, the 4 Simconnect modules installed on second PC (There are only 4 versions as far as I know) and the C++ modules installed on the computers.
4th picture is the slave PC's screen which is mounted on an arm just under the main 3 screens from the big-rig..
Surely, with everything plugged in, and GIT recognising everything, the tabs should light up and allow me to configure things?
So, any help you can provide at this stage, is desperately needed and appreciated.
I've been missing flying properly for months and months mate... Sick of being a Flight sim problem non-fixer...
Heck I've even bought XP11, and your XP11 GIT, going to try that next...
If that is all OK, check the entry in the FAQ called "FSX/P3D/FSX SE Crashes on start up indicating an error with the Goflight Interface Module" here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/70-faq-goflight-interface-tool.html
Thanks mate, few questions on that...
Where is the dll.xml file I be checking? (Where would it typically be found) and what should I expect to see, that if it is not there, I should put there?
If it is not there, run the GIT setup again and it should add it.
GIT Runs on Slave PC, which has all of the GoFlight kit connected to it, and nothing else.
Clearly I need to fool GIT into thinking its on the main PC, so what would you recommend is the best way to do this?
I found the dll.xml file, copy/pasted the FSUIPC entry and simply changed it to load the GoFlight Interface Module.dll using the network share path, so was trying to tell P3D that it needs to load that GIT dll file from the second computer, but alas, that didnt work.
Weird, because GIT reloads when told to, it also picks up the name of the aircraft correctly, but keeps saying "The computer actively refused the connection" quoting a local IP of 127.0.0.0 which is a computers own IP address when it cannot connect.
I even installed the 4 simconnect modules onto the main PC too, so now they are on both computers..
I would then disable all firewalls and AV software on both PC's. Make sure GIT frontend is not running on the server (leave it installed as it needs the dll module running on the server only).
Double check you have simconnect setup for working across a network e.g. http://hifisupport.kayako.com/Knowledgebase/Article/View/6/8/instructions-for-networked-configuration-with-simconnect
GIT doesn't need any shared folders. Install GIT on the client PC and fire it up.
I installed GIT on the main PC, and did nothing else at all, and I got 3 green lights and controls started working.
Not quite properly, but some are now working.
Things like the LGT2, trims will work in 1 direction but not the other, gear up works but gear down doesnt.
Simconnect was setup correctly, it just seems that what you said previously about P3D not loading that xml.dll file must have been the case.
I'm now thinking that because its loading the xml file from its own local install instead of the remote install, this may be why its flakey, and some stuff works and some doesnt?
I was just using the Baron 58, at biggin hill, in P3D v3 for this, but am about to re-install again from scratch due to replacing hard drives and graphics card..
Now I had it working, am confident I can get it working again with P3Dv4, however, would it be wise to edit the dll.xml file to set the network path to "GoFlight Interface Module.dll" so that it doesnt try to use its own local copy?
The dll needs to be running on the server PC only with no GIT frontend running. The client just needs the GIT frontend and no dll.
Firewalls remained on, but AV disabled temporarily..
The only thing that actually seemed to make the difference was installing GIT on the main PC, which is when things started to work.
Will do a re-run of P3Dv4 and see how far I get with the setup, from fresh, so it may be a week or two..
Having just replace 2 ATI Radeon 6990's for a 1080ti, and seeing frame rates double @ 7680 x 1440 to 45fps, it kinda bought new life to my sim :-)
Initial testing with the Baron 58@
1. Programmed the TQ6 throttles and flaps, all ok... Eventually figure out the "Calibrate" button gave me full throttle..
2. LGT2 > Bit of a nightmare figuring out the gear up/down, as its not consistent... 1 minute it works fine, then it stops. 2 or 3 up/down selections not doing it fast either, then it just stops working. I do "Gear up, then wait a few seconds after gear is up and lights go out, then do gear down.. wait 5 after the 3 green lights, then gear up.. So, thats an issue now.
3. T8 - Switch panel - Trying to program 1 switch for parking brake on/off... Holy cow, I dont remember it being as complicated as this. All I want is to have parking brake on + green light on, and Parking brake off, light off.. Any simple advice you can give for this would be awesome. Then I can copy it, as I have 4 switch panels.
But, initial results look like everything is working in terms of simconnect, all I did was install GITv4 on the main PC, put the simconnect files back in the right place and away we went.
Any help you can give with the gear up/down would be awesome...
Thanks Steve...
Rich
Event: PARKING_BRAKES
Event Action: NOTHING
Light Data: BRAKE PARKING POSITION
Light Action: ON_GREATER_THAN
Light Value: 0
Only when the first item is working do I move onto the second, this time. Will let you know how it goes over the weekend.
