Which GFMCPPRO xml file to use with IXEG 737 (MCP PRO and EFIS) by Steve McNitt (aka Slayer)
I've downloaded this config for the IXEG 737. There are two xml files for the MCP PRO. One is named B733_GFMCPPRO.xml and the other is named B733_GFMCPPRO-0.xml. The two files have slightly different entries near the bottom and the latter is dated about a month later than the other. What is the difference between these two files and which should I use?
Robert
Robert
