Bespoke events changed - in the background XP-11
I have programmed the 757-200 and did my own bespoke events, and assigned the events to my Go-flight modules, somehow not sure but my entire set up has just changed the bespoke events. ie I program for example:_b757_elec_bat_pwr_off, and similarly the on event. When I restart my PC the name is the same but the actual event coding has changed. This is happening through all events and modules, one day the Mcp will work perfectly, then the actual events are changed and things that worked before is now recoded to something else.
Example included in the screen shot, This as programmed as landing light Centre on, now the 1-sim/jettison has over written my previous programmed event, even the light data has been changed.
How can I prevent this as now I need to do 14 goflight units again, and this happens across all my aircraft.
Andre
Andre
1. I create and name a bespoke event, _B757_lights.... where you see on the detective the coding 1-sim/jettison... that is what is changing it used to be anim/button14
2. I assign it to the button
3. It works, when I restart my machine the actual coding of the event changes, whilst it keeps the name of the event it then also changes the light data on GFT. on the GFT you can see the B757 switch event that did not change just the coding for the event itself.
4. I never programed any event to be 1-sim/jettison....
thanks
Attached my current version reprogrammed, Boeing 757-200V2017 professional is the aircraft from Flight factor
Just went to test and realised you have not included the Bespoke Events. You will need to export those via Detective and add them here.
It could be either your config file is corrupt or you are using another aircraft that matches the aircraft name of the FF and its screwing up the config.
If you zip up Documents\GoFlight Interface Tool and attach here, I can try with your exact configuration.
