Mcp p3dv4
bye i bought interface dool for p3d but now I'm update to p3dv4 and it will not work. can you help me please?
«1
    What aircraft are you using it with? Does the default baron work OK (after clicking FS Default)? Have you installed the hotfix 1 version of the P3Dv4?
    If its PMDG aircraft, you need to install the latest versions. Download from their website then apply any updates using their Operations Center software. If the controls work with PMDG, but not the displays, please read the entry "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes)" in the FAQ here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/70-faq-goflight-interface-tool.html
    If you still have problems, please copy and paste the GIT log here once the aircraft is loaded to the VC state.
  • 16:05:13 GoFlight Connection Starting.....
    16:05:13 SimConnect Connection Starting.....
    16:05:16 GoFlight Connection Started
    16:05:42 SimConnect Message Processing Started
    16:05:42 SimConnect Connection Started
    16:05:42 Aircraft Connection Starting.....
    16:05:46 FSUIPC: Connection Failed: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione 127.0.0.1:8385
    16:05:46 Aircraft Connection Started
    16:05:46 Simconnect Version: 3.4.0.0
    16:05:46 Aircraft FullName: Generic
    16:05:46 Synchronising Switches & Selectors .....
    16:05:46 Synchronising Switches & Selectors: Waiting for SimConnect .....
    16:05:58 SimConnect: Event Received: Start
    16:05:59 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    16:05:59 SimConnect: Event Received: SIM, 0
    16:05:59 SimConnect: Event Received: PAUSE, 0
    16:06:18 PMDG SDK option is OK in Prepar3D v4
    16:06:18 SimConnect: Event Received: Aircraft Type Changed
    16:06:18 SimConnect Message Processing Finished
    16:06:19 GoFlight Connection Starting.....
    16:06:19 SimConnect Connection Starting.....
    16:06:20 SimConnect Message Processing Started
    16:06:20 SimConnect Connection Started
    16:06:20 Aircraft Connection Starting.....
    16:06:21 GoFlight Connection Started
    16:06:22 Aircraft Connection Started
    16:06:22 Simconnect Version: 3.4.0.0
    16:06:22 Aircraft FullName: PMDG 737-700NGX WL
    16:06:32 SimConnect: Event Received: Start
    16:06:32 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    16:06:32 SimConnect: Event Received: SIM, 0
    16:06:32 SimConnect: Event Received: PAUSE, 0
    16:07:24 SimConnect: Event Received: SIMSTART, 0
    16:07:24 SimConnect: Event Received: SIM, 1
    16:07:54 Synchronising Switches & Selectors Complete
  • good evening Steve
    don't work
  • Log looks OK.
    Have you enabled the MCP on the MCP tab? What version of the NGX are you running?
  • Ngx 1.20.8414
    and where do i need to enable mcp? in which card?
  • Its the GIT MCP tab. You need to select Device 0 from the drop down list and then Pick ENABLED from the list next to it.
  • does not allow me to access the mcp window remains dark gray
  • Do you have the MCP or the MCP PRO?
  • now i did device 0 and enable but the same does not want to work. I am going crazy
  • Ok, so now you have enabled the device, quit GIT and restart it. Do the controls work but the displays remain blank or zero?
  • it lights up but there are dashes remaining
  • OK, but do the controls work?
  • Yes are all 3 on the green
  • No, I mean turn the altitude knob and see if the MCP in the Virtual Cockpit of the NGX changes.
  • it works and now it's all zero
  • OK. There are 5 potential causes:
    1) You are not running the latest versions of the NGX, 777, 747. GIT is always built to work with the very latest version only.
    2) The PMDG NGX, 777 or 747 will stop sending messages via their SDK and thus into this driver if
    - the aircraft is flown and then you return to the FSX main menu and re-fly it again;
    - switch between different models;
    - your default flight is set to use the NGX, 777 or 747 and then you change to another NGX/777/747 aircraft or model;
    It will manifest itself as the displays on the MCP PRO not updating, although you can use buttons and switches on the MCP PRO and the NGX/777/747 will respond. You will also notice no activity on the PMDG status LED on the Status Tab.
    PMDG have acknowledged this as an issue with FSX/Simconnect and is why they always recommend to restart FSX after each flight with the NGX/777/747.
    3) It may also be due to the PMDG SDK not being enabled. The enabling of the SDK is automatic if you have "FSX Enabled" and/or "Prepar3D Enabled" (whichever is appropriate) ticked on the Settings tab. You can check or set this option manually by using notepad to open the follow file(s):
    For the NGX: \PMDG\PMDG 737 NGX\737NGX_Options.ini
    For the 777: \PMDG\PMDG 777X\777X_Options.ini
    For the 747: \PMDG\PMDG 747 QOTS II\747QOTSII_Options.ini
    and ensure the following exists:
    [SDK]
    EnableDataBroadcast=1 (if this is set to 0 change it to 1)
    4) On some systems the Flight Simulator software and the GoFlight Interface Tool need to be run as Administrator. Right click on the program concerned (e.g. FSX.exe and afterwards GoFlight Interface Tool.exe). Select the compatibility tab and tick run this program as administrator.
    5) You do not have the latest .NET Framework installed.
  • I have 737 no 777 or 747
  • And don't work.only 0
  • the NGX is the 737 so the steps do apply.
    Getting zeros is always due to one of the 5 things above. If you are absolutely certain all 5 things are correct, then I can only recommend uninstalling the NGX/737 and reinstalling as Administrator using the latest installer from the PMDG website. DO NOT apply any updates using the PMDG operations center. Run GIT, allow it to configure the NGX settings file. Quit GIT and then reload it.
  • what is the last ngx version? I have 1.20.8414 and what is the net framework?
  • That is the latest version. .NET Framework is a software development framework. Normally running Windows Update ensures you have the latest version. You can also manually install it here: https://www.microsoft.com/en-us/download/details.aspx?id=53344
  • Also, make sure the NGX is not set as your default flight.
  • nothing works, sorry but I do everything you say but it does not work
  • buttons work x 1 minute and then locks
  • What version of p3Dv4 are you running?
  • Copy and paste the log after It has locked.
  • 4.0.23.21468
  • You are not running the latest version. You need 4.0.28.21686 (the hotfix 1 version). The earlier version had Simconnect bugs.
  • 18:46:33 GoFlight Connection Starting.....
    18:46:33 SimConnect Connection Starting.....
    18:46:34 SimConnect Message Processing Started
    18:46:34 GoFlight Connection Started
    18:46:34 SimConnect Connection Started
    18:46:34 Aircraft Connection Starting.....
    18:46:34 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    18:46:34 SimConnect: Event Received: SIM, 0
    18:46:34 SimConnect: Event Received: PAUSE, 0
    18:46:37 FSUIPC: Connection Failed: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione 127.0.0.1:8385
    18:46:37 Aircraft Connection Started
    18:46:37 Simconnect Version: 3.4.0.0
    18:46:37 Aircraft FullName: IRIS Raptor Driver
    18:46:37 Synchronising Switches & Selectors .....
    18:46:37 Synchronising Switches & Selectors: Waiting for SimConnect .....
    18:46:48 PMDG SDK option is OK in Prepar3D v4
    18:46:48 SimConnect: Event Received: Aircraft Type Changed
    18:46:48 GoFlight Connection Starting.....
    18:46:48 SimConnect Message Processing Finished
    18:46:49 SimConnect Connection Starting.....
    18:46:49 Joystick Device Found: USB Game Controllers
    18:46:50 Device Found: MCP Pro
    18:46:50 Device Found: ASUS Wireless Radio Control
    18:46:50 Device Found: Logitech USB Headset H540
    18:46:50 SimConnect Message Processing Started
    18:46:50 Supp Device Found: BU0836X Interface 2
    18:46:50 Mouse Device Found: Mouse
    18:46:50 SimConnect Connection Started
    18:46:50 Aircraft Connection Starting.....
    18:46:50 Keyboard Device Found: Tastiera
    18:46:50 Joystick Found Device 0: USB Game Controllers
    18:46:50 Device 0 Button Count: 8
    18:46:50 Device 0 POV Count:1
    18:46:50 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    18:46:50 SimConnect: Event Received: SIM, 0
    18:46:50 SimConnect: Event Received: PAUSE, 1
    18:46:51 GoFlight Connection Started
    18:46:51 Aircraft Connection Started
    18:46:51 Simconnect Version: 3.4.0.0
    18:46:51 Aircraft FullName: PMDG 737-800NGX WL
    18:47:13 SimConnect: Event Received: SIMSTART, 0
    18:47:13 SimConnect: Event Received: SIM, 1
    18:47:28 Send Control Data: Too Many Retries
    18:47:29 Send Control Data: Too Many Retries
    18:47:30 Send Control Data: Too Many Retries
    18:47:31 Send Control Data: Too Many Retries
    18:47:32 Send Control Data: Too Many Retries
    18:47:33 Send Control Data: Too Many Retries
    18:47:34 Send Control Data: Too Many Retries
    18:47:35 Send Control Data: Too Many Retries
    18:47:36 Send Control Data: Too Many Retries
    18:47:37 Send Control Data: Too Many Retries
    18:47:38 Send Control Data: Too Many Retries
    18:47:40 Send Control Data: Too Many Retries
    18:47:41 Send Control Data: Too Many Retries
    18:47:42 Send Control Data: Too Many Retries
    18:47:43 Send Control Data: Too Many Retries
    18:47:44 Send Control Data: Too Many Retries
    18:47:45 Send Control Data: Too Many Retries
    18:47:46 Send Control Data: Too Many Retries
    18:47:47 Send Control Data: Too Many Retries
    18:47:48 Send Control Data: Too Many Retries
    18:47:49 Send Control Data: Too Many Retries
    18:47:50 Send Control Data: Too Many Retries
    18:47:51 Send Control Data: Too Many Retries
    18:47:53 Send Control Data: Too Many Retries
    18:47:54 Send Control Data: Too Many Retries
    18:47:58 Send Control Data: Too Many Retries
    18:47:59 Send Control Data: Too Many Retries
    18:48:03 Send Control Data: Too Many Retries
    18:48:07 Send Control Data: Too Many Retries
    18:48:08 Send Control Data: Too Many Retries
    18:48:12 Send Control Data: Too Many Retries
    18:48:13 Send Control Data: Too Many Retries
    18:48:17 Send Control Data: Too Many Retries
    18:48:18 Send Control Data: Too Many Retries
    18:48:22 Send Control Data: Too Many Retries
    18:48:23 Send Control Data: Too Many Retries
    18:48:27 Send Control Data: Too Many Retries
    18:48:31 Send Control Data: Too Many Retries
    18:48:32 Send Control Data: Too Many Retries
    18:48:36 Send Control Data: Too Many Retries
    18:48:37 Send Control Data: Too Many Retries
    18:48:41 Send Control Data: Too Many Retries
    18:48:42 Send Control Data: Too Many Retries
    18:48:46 Send Control Data: Too Many Retries
    18:48:47 Send Control Data: Too Many Retries
    18:48:51 Send Control Data: Too Many Retries
    18:48:55 Send Control Data: Too Many Retries
    18:48:56 Send Control Data: Too Many Retries
    18:49:00 Send Control Data: Too Many Retries
    18:49:01 Send Control Data: Too Many Retries
    18:49:05 Send Control Data: Too Many Retries
    18:49:06 Send Control Data: Too Many Retries
    18:49:10 Send Control Data: Too Many Retries
    18:49:11 Send Control Data: Too Many Retries
    18:49:15 Send Control Data: Too Many Retries
    18:49:19 Send Control Data: Too Many Retries
    18:49:20 Send Control Data: Too Many Retries
    18:49:24 Send Control Data: Too Many Retries
    18:49:25 Send Control Data: Too Many Retries
    18:49:29 Send Control Data: Too Many Retries
    18:49:30 Send Control Data: Too Many Retries
    18:49:34 Send Control Data: Too Many Retries
    18:49:35 Send Control Data: Too Many Retries
    18:49:39 Send Control Data: Too Many Retries
    18:49:40 Send Control Data: Too Many Retries
    18:49:44 Send Control Data: Too Many Retries
    18:49:48 Send Control Data: Too Many Retries
    18:49:49 Send Control Data: Too Many Retries
    18:49:53 Send Control Data: Too Many Retries
    18:49:54 Send Control Data: Too Many Retries
