Mcp p3dv4
bye i bought interface dool for p3d but now I'm update to p3dv4 and it will not work. can you help me please?
What aircraft are you using it with? Does the default baron work OK (after clicking FS Default)? Have you installed the hotfix 1 version of the P3Dv4?
If its PMDG aircraft, you need to install the latest versions. Download from their website then apply any updates using their Operations Center software. If the controls work with PMDG, but not the displays, please read the entry "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes)" in the FAQ here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/70-faq-goflight-interface-tool.html
If you still have problems, please copy and paste the GIT log here once the aircraft is loaded to the VC state.
16:05:13 SimConnect Connection Starting.....
16:05:16 GoFlight Connection Started
16:05:42 SimConnect Message Processing Started
16:05:42 SimConnect Connection Started
16:05:42 Aircraft Connection Starting.....
16:05:46 FSUIPC: Connection Failed: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione 127.0.0.1:8385
16:05:46 Aircraft Connection Started
16:05:46 Simconnect Version: 3.4.0.0
16:05:46 Aircraft FullName: Generic
16:05:46 Synchronising Switches & Selectors .....
16:05:46 Synchronising Switches & Selectors: Waiting for SimConnect .....
16:05:58 SimConnect: Event Received: Start
16:05:59 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
16:05:59 SimConnect: Event Received: SIM, 0
16:05:59 SimConnect: Event Received: PAUSE, 0
16:06:18 PMDG SDK option is OK in Prepar3D v4
16:06:18 SimConnect: Event Received: Aircraft Type Changed
16:06:18 SimConnect Message Processing Finished
16:06:19 GoFlight Connection Starting.....
16:06:19 SimConnect Connection Starting.....
16:06:20 SimConnect Message Processing Started
16:06:20 SimConnect Connection Started
16:06:20 Aircraft Connection Starting.....
16:06:21 GoFlight Connection Started
16:06:22 Aircraft Connection Started
16:06:22 Simconnect Version: 3.4.0.0
16:06:22 Aircraft FullName: PMDG 737-700NGX WL
16:06:32 SimConnect: Event Received: Start
16:06:32 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
16:06:32 SimConnect: Event Received: SIM, 0
16:06:32 SimConnect: Event Received: PAUSE, 0
16:07:24 SimConnect: Event Received: SIMSTART, 0
16:07:24 SimConnect: Event Received: SIM, 1
16:07:54 Synchronising Switches & Selectors Complete
don't work
Have you enabled the MCP on the MCP tab? What version of the NGX are you running?
and where do i need to enable mcp? in which card?
1) You are not running the latest versions of the NGX, 777, 747. GIT is always built to work with the very latest version only.
2) The PMDG NGX, 777 or 747 will stop sending messages via their SDK and thus into this driver if
- the aircraft is flown and then you return to the FSX main menu and re-fly it again;
- switch between different models;
- your default flight is set to use the NGX, 777 or 747 and then you change to another NGX/777/747 aircraft or model;
It will manifest itself as the displays on the MCP PRO not updating, although you can use buttons and switches on the MCP PRO and the NGX/777/747 will respond. You will also notice no activity on the PMDG status LED on the Status Tab.
PMDG have acknowledged this as an issue with FSX/Simconnect and is why they always recommend to restart FSX after each flight with the NGX/777/747.
3) It may also be due to the PMDG SDK not being enabled. The enabling of the SDK is automatic if you have "FSX Enabled" and/or "Prepar3D Enabled" (whichever is appropriate) ticked on the Settings tab. You can check or set this option manually by using notepad to open the follow file(s):
For the NGX: \PMDG\PMDG 737 NGX\737NGX_Options.ini
For the 777: \PMDG\PMDG 777X\777X_Options.ini
For the 747: \PMDG\PMDG 747 QOTS II\747QOTSII_Options.ini
and ensure the following exists:
[SDK]
EnableDataBroadcast=1 (if this is set to 0 change it to 1)
4) On some systems the Flight Simulator software and the GoFlight Interface Tool need to be run as Administrator. Right click on the program concerned (e.g. FSX.exe and afterwards GoFlight Interface Tool.exe). Select the compatibility tab and tick run this program as administrator.
5) You do not have the latest .NET Framework installed.
Getting zeros is always due to one of the 5 things above. If you are absolutely certain all 5 things are correct, then I can only recommend uninstalling the NGX/737 and reinstalling as Administrator using the latest installer from the PMDG website. DO NOT apply any updates using the PMDG operations center. Run GIT, allow it to configure the NGX settings file. Quit GIT and then reload it.
18:46:33 SimConnect Connection Starting.....
18:46:34 SimConnect Message Processing Started
18:46:34 GoFlight Connection Started
18:46:34 SimConnect Connection Started
18:46:34 Aircraft Connection Starting.....
18:46:34 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
18:46:34 SimConnect: Event Received: SIM, 0
18:46:34 SimConnect: Event Received: PAUSE, 0
18:46:37 FSUIPC: Connection Failed: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione 127.0.0.1:8385
18:46:37 Aircraft Connection Started
18:46:37 Simconnect Version: 3.4.0.0
18:46:37 Aircraft FullName: IRIS Raptor Driver
18:46:37 Synchronising Switches & Selectors .....
18:46:37 Synchronising Switches & Selectors: Waiting for SimConnect .....
18:46:48 PMDG SDK option is OK in Prepar3D v4
18:46:48 SimConnect: Event Received: Aircraft Type Changed
18:46:48 GoFlight Connection Starting.....
18:46:48 SimConnect Message Processing Finished
18:46:49 SimConnect Connection Starting.....
18:46:49 Joystick Device Found: USB Game Controllers
18:46:50 Device Found: MCP Pro
18:46:50 Device Found: ASUS Wireless Radio Control
18:46:50 Device Found: Logitech USB Headset H540
18:46:50 SimConnect Message Processing Started
18:46:50 Supp Device Found: BU0836X Interface 2
18:46:50 Mouse Device Found: Mouse
18:46:50 SimConnect Connection Started
18:46:50 Aircraft Connection Starting.....
18:46:50 Keyboard Device Found: Tastiera
18:46:50 Joystick Found Device 0: USB Game Controllers
18:46:50 Device 0 Button Count: 8
18:46:50 Device 0 POV Count:1
18:46:50 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
18:46:50 SimConnect: Event Received: SIM, 0
18:46:50 SimConnect: Event Received: PAUSE, 1
18:46:51 GoFlight Connection Started
18:46:51 Aircraft Connection Started
18:46:51 Simconnect Version: 3.4.0.0
18:46:51 Aircraft FullName: PMDG 737-800NGX WL
18:47:13 SimConnect: Event Received: SIMSTART, 0
18:47:13 SimConnect: Event Received: SIM, 1
18:47:28 Send Control Data: Too Many Retries
18:47:29 Send Control Data: Too Many Retries
18:47:30 Send Control Data: Too Many Retries
18:47:31 Send Control Data: Too Many Retries
18:47:32 Send Control Data: Too Many Retries
18:47:33 Send Control Data: Too Many Retries
18:47:34 Send Control Data: Too Many Retries
18:47:35 Send Control Data: Too Many Retries
18:47:36 Send Control Data: Too Many Retries
18:47:37 Send Control Data: Too Many Retries
18:47:38 Send Control Data: Too Many Retries
18:47:40 Send Control Data: Too Many Retries
18:47:41 Send Control Data: Too Many Retries
18:47:42 Send Control Data: Too Many Retries
18:47:43 Send Control Data: Too Many Retries
18:47:44 Send Control Data: Too Many Retries
18:47:45 Send Control Data: Too Many Retries
18:47:46 Send Control Data: Too Many Retries
18:47:47 Send Control Data: Too Many Retries
18:47:48 Send Control Data: Too Many Retries
18:47:49 Send Control Data: Too Many Retries
18:47:50 Send Control Data: Too Many Retries
18:47:51 Send Control Data: Too Many Retries
18:47:53 Send Control Data: Too Many Retries
18:47:54 Send Control Data: Too Many Retries
18:47:58 Send Control Data: Too Many Retries
18:47:59 Send Control Data: Too Many Retries
18:48:03 Send Control Data: Too Many Retries
18:48:07 Send Control Data: Too Many Retries
18:48:08 Send Control Data: Too Many Retries
18:48:12 Send Control Data: Too Many Retries
18:48:13 Send Control Data: Too Many Retries
18:48:17 Send Control Data: Too Many Retries
18:48:18 Send Control Data: Too Many Retries
18:48:22 Send Control Data: Too Many Retries
18:48:23 Send Control Data: Too Many Retries
18:48:27 Send Control Data: Too Many Retries
18:48:31 Send Control Data: Too Many Retries
18:48:32 Send Control Data: Too Many Retries
18:48:36 Send Control Data: Too Many Retries
18:48:37 Send Control Data: Too Many Retries
18:48:41 Send Control Data: Too Many Retries
18:48:42 Send Control Data: Too Many Retries
18:48:46 Send Control Data: Too Many Retries
18:48:47 Send Control Data: Too Many Retries
18:48:51 Send Control Data: Too Many Retries
18:48:55 Send Control Data: Too Many Retries
18:48:56 Send Control Data: Too Many Retries
18:49:00 Send Control Data: Too Many Retries
18:49:01 Send Control Data: Too Many Retries
18:49:05 Send Control Data: Too Many Retries
18:49:06 Send Control Data: Too Many Retries
18:49:10 Send Control Data: Too Many Retries
18:49:11 Send Control Data: Too Many Retries
18:49:15 Send Control Data: Too Many Retries
18:49:19 Send Control Data: Too Many Retries
18:49:20 Send Control Data: Too Many Retries
18:49:24 Send Control Data: Too Many Retries
18:49:25 Send Control Data: Too Many Retries
18:49:29 Send Control Data: Too Many Retries
18:49:30 Send Control Data: Too Many Retries
18:49:34 Send Control Data: Too Many Retries
18:49:35 Send Control Data: Too Many Retries
18:49:39 Send Control Data: Too Many Retries
18:49:40 Send Control Data: Too Many Retries
18:49:44 Send Control Data: Too Many Retries
18:49:48 Send Control Data: Too Many Retries
18:49:49 Send Control Data: Too Many Retries
18:49:53 Send Control Data: Too Many Retries
18:49:54 Send Control Data: Too Many Retries
