Not working at all
I have ourchased the interface tool as I have new PC running Prepare 3D with a MCPPRO I used with my last FS 4 years ago. It just doesn't work. If I try to load a plane in the set up it just crashes and despite all connections working the MCP PRO still locks up when I turn knobs. Feel like I light have wasted £29.99.
For a basic test, Can you load up the default beech baron so its in the virtual cockpit. Start GIT and confirm the Detective button is enabled. If so, go to the MCP PRO tab, click FS Default and then enable the MCP PRO in GIT. Quit QIT and reload it. Does the MCP PRO work properly? IF not, what happens? Can you copy and paste the GIT log?
P3D version 4.0.28 on Windows 10. Have tried what you suggest and MCP worked for a few turns (which is an improvement) but then locked up. Log is here:
13:24:54 GoFlight Connection Starting.....
13:24:54 SimConnect Connection Starting.....
13:24:55 SimConnect Message Processing Started
13:24:55 GoFlight Connection Started
13:24:55 SimConnect Connection Started
13:24:55 Aircraft Connection Starting.....
13:24:55 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
13:24:55 SimConnect: Event Received: SIM, 1
13:24:55 SimConnect: Event Received: PAUSE, 1
13:24:58 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
13:24:58 Aircraft Connection Started
13:24:58 Simconnect Version: 3.4.0.0
13:24:58 Aircraft FullName: beech_baron_58
13:24:58 Synchronising Switches & Selectors .....
13:24:58 LvarNamesUpdated!
13:24:58 Creating Bespoke Vars
13:24:58 Bespoke Vars Created
13:24:58 Importing Bespoke Variables
13:24:58 Bespoke Vars Assigned, Importing Bespoke Events
13:24:58 Bespoke Events Temp Imported
13:24:58 Bespoke Events Imported
13:24:58 Loading Aircraft Settings
13:24:58 GetXMLConfigData
13:24:58 GotXMLConfigData
13:24:58 Loading Power
13:24:58 Loading MCPPRO
13:24:58 Loading EFIS
13:24:58 Loading P8
13:24:58 Loading T8
13:24:58 Loading RP48
13:24:58 Loading MESM
13:24:58 Loading WP6
13:24:58 Loading LGT
13:24:58 Loading LGT II
13:24:58 Loading GF46
13:24:58 Loading GF45
13:24:58 Loading TQ6
13:24:58 Loading DIO
13:24:58 Loading GF166
13:24:58 Loading SECM
13:24:58 Loading Joysticks
13:24:58 Clearing Displays
13:24:58 Reset Data
13:24:58 Aircraft Settings Loaded
13:24:58 Calling Aircraft Changed
13:24:59 Aircraft Changed
13:25:00 Synchronising Switches & Selectors Complete
Andy
We can purse resolving the issues in GIT by getting the Beech Baron to work OK by increasing the CMD and Write Delay sliders on the GIT tab until the MCP PRO becomes more stable or you can contact GoFlight and see if they will upgrade the firmware for you.
Again, double check you have it on USB 2 or 1 as it will cause the MCP PRO to lock up and generally misbehave.
In GoFlights drivers readme.txt file they talk about using USB 1 for older devices that lock up. Not sure if you have an old USB 1 expansion card you could install?
Let me know how you wish to proceed.
The sliders will be trial and error as each PC is different. The higher the values, the more sluggish the MCP PRO will feel, but the less likely it will be to lock up.
Once you have a stable system, we can look at the crash you had reported earlier.
Keep me posted.
