Lights don't work,
Since installing 2.0.1049, I'm getting mixed result with the NGX. Very often, none of my modules lights comes on. The interface shows 3 green lights. If I click restart, the lights will come on momentarliy but then turn off. The buttons and switches still work though. In the logs I see a simconnect error, Nothing really changed in my setup. Quitting FSX and restarting does not fix the issue. I got it to work a few times but that's it.
15:05:14 GoFlight Connection Starting.....
15:05:14 SimConnect Connection Starting.....
15:05:15 GoFlight Connection Started
15:05:16 SimConnect Message Processing Started
15:05:16 SimConnect Connection Started
15:05:16 Aircraft Connection Starting.....
15:05:16 PMDG SDK option is OK in FSX
15:05:16 SimConnect: Event Received: Aircraft Type Changed
15:05:16 SimConnect: Event Received: SIM, 1
15:05:16 SimConnect: Event Received: PAUSE, 0
15:05:16 GoFlight Connection Starting.....
15:05:16 SimConnect Message Processing Finished
15:05:16 SimConnect Connection Starting.....
15:05:17 SimConnect Message Processing Started
15:05:18 SimConnect Connection Started
15:05:18 Aircraft Connection Starting.....
15:05:18 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
15:05:18 SimConnect: Event Received: SIM, 1
15:05:18 SimConnect: Event Received: PAUSE, 0
15:05:18 GoFlight Connection Started
15:05:19 Aircraft Connection Started
15:05:19 SimConnect: Exception Received: EVENT_ID_DUPLICATE
15:05:19 Synchronising Switches & Selectors .....
15:05:19 SimConnect: Exception Received: ERROR
15:05:20 SimConnect: Exception Received: ERROR
15:05:21 SimConnect: Exception Received: ERROR
15:05:22 SimConnect: Exception Received: ERROR
15:05:23 SimConnect: Exception Received: ERROR
15:05:24 SimConnect: Exception Received: ERROR
15:05:25 SimConnect: Exception Received: ERROR
15:05:26 SimConnect: Exception Received: ERROR
15:05:27 SimConnect: Exception Received: ERROR
15:05:28 SimConnect: Exception Received: ERROR
15:05:29 SimConnect: Exception Received: ERROR
15:05:30 SimConnect: Exception Received: ERROR
15:05:31 SimConnect: Exception Received: ERROR
15:05:32 SimConnect: Exception Received: ERROR
15:05:33 SimConnect: Exception Received: ERROR
15:05:34 SimConnect: Exception Received: ERROR
15:05:35 SimConnect: Exception Received: ERROR
15:05:36 SimConnect: Exception Received: ERROR
15:05:37 SimConnect: Exception Received: ERROR
15:05:38 SimConnect: Exception Received: ERROR
15:05:39 SimConnect: Exception Received: ERROR
15:05:40 SimConnect: Exception Received: ERROR
15:05:41 SimConnect: Exception Received: ERROR
15:05:42 SimConnect: Exception Received: ERROR
15:05:43 SimConnect: Exception Received: ERROR
15:05:44 SimConnect: Exception Received: ERROR
15:05:45 SimConnect: Exception Received: ERROR
15:05:46 SimConnect: Exception Received: ERROR
15:05:49 Synchronising Switches & Selectors Complete
15:06:00 SimConnect: Event Received: SIMSTOP, 0
15:06:00 SimConnect: Event Received: SIM, 0
15:06:00 SimConnect: Event Received: SIMSTART, 0
15:06:00 SimConnect: Event Received: SIM, 1
Can you attach your config files for me to try.
Sorry, I should have been more specific, I need the files stored in My Documents\Goflight Interface Tool
Just tested your files and it all works OK for me. There is clearly a problem though because of all the ERROR's you are seeing.
Can you try reinstalling the software and ensuring Windows update is fully complete. Make sure FSX is not running when you reinstall the interface.
Also, are you using Windows 8?
Can you also try using an older version and see if the errors stop.
Let me know how you get on.
Tx
Redownload 1049 before reinstalling in case its a corrupt download.
The other versions available:
1013: https://www.dropbox.com/s/pxjnx9fc2u2sjpy/Goflight%20Interface%20Tool%202-0-1013-0.zip
1011: https://www.dropbox.com/s/zmgqclgbjamor64/Goflight%20Interface%20Tool%202-0-1011-0.zip
Not sure what to do at this point. Maybe a W7 issue?
I should probably mentionned that before that I also tried the GIT 2.0.1111 which did not work either.
I still see all these simconnect errors in the log though.
Not sure what is going on...
Cheers!
Can you check in GIT that the devices are enabled and the brightness is set to 10. Also make sure that GFConfig has a profile loaded that does not have anything set for the devices and the MCP PRO and EFIS is set to compatible add-on.
Can you also list all your GoFlight gear including quantities.
In the meantime, here's my list of GF devices:
1 x EFIS
1 x MCP Pro
T8-1 and T8-2 (one of each)
1 x P8
1 x GF166
1 x GF-46 (which mostly never works. Does work when set through GFconfig and no GIT running...).
Cheers and tx for your support!
LP
