GF-45 (X-plane 11)
Hi All,
In the setting tab with 45R I see 8 options.
What is the meaning of those options as i have only 2 rotaries?
I managed to get 1 rotary working but the manual is only generic and is not specific for GF-45.
Thanks!
Thanks!
steve
Indeed want to have a button on my GF-P8 to cycle through the configs which i setup.
I now installed version 2.0. What i discovered till now is the following:
1. I setup the first option on the GF45 display. i.e. IAS speed.
2. Then i setup the second option to display the Heading
3. When i clicked on option one again it was not saved.
4. I exported the xml and IAS speed setting was dissappeared
Any clue what i am doing wrong here?
Running X-Plane 11, Windows 7 Ultimate
Thanks again
Let me know if you need something!
How can i set the display on the GF45 to NOT display decimals behind the dot. So i.e. 218 and not 218.39 for speed or heading?
I reprogrammed it and works fine now. Try to do a test in the afternoon and if i found something will sent it to you.
By the way... the P8 has only a Led per push button ;-)
I uploaded a complete config for the 737-800 and working now on the A320NEO from Jardesign...
