Moving to Windows 10 from Windows 7
2»
  • Each BIOS is different, if you can take some photos of the options and pin them here and will take a look.
  • Ok will do.....I will do that when I get home after work. I believe you are 6-7 hours ahead of me here..... thanks again Steve....
    Scott
  • Hi Scott,
    Not sure if you are still working on this or moved on, but I have found two BIOS settings that will kill the GF46 and GF166 on my system. I needed XHCI Handoff to be Enabled and Legacy Support Enabled.
