Connection delay since P3Dv4.1
Since installing P3Dv4.1/GIT 3.4.1.0, I've been experiencing a connection delay of around 30 secs each time I start GIT. This happens regardless of aircraft.
During the delay, the GoFlight and SimConnect icons on the Status page are green with the Aircraft icon showing red. After the delay, the Aircraft icon flashes green.
Not sure if this is connected, but I've also noticed the HEADING rotary has stopped working when using the Aerosoft CRJ X (I'm using the config downloaded from your web site). The MCP-PRO display updates when using the mouse to turn the HEADING rotary in the VC, but turning the rotary on the unit has no effect. This was working previous to installing P3Dv4.1. When testing the event in Detective, it works fine however.
Both P3Dv4 and GIT are being run as administrator.
Below are the log entries I'm seeing on starting GIT - please let me know if you need any further info.
Dennis
17:51:15 GoFlight Connection Starting.....
17:51:15 SimConnect Connection Starting.....
17:51:16 SimConnect Message Processing Started
17:51:16 GoFlight Connection Started
17:51:16 SimConnect Connection Started
17:51:16 Aircraft Connection Starting.....
17:51:16 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
17:51:16 SimConnect: Event Received: SIM, 1
17:51:16 SimConnect: Event Received: PAUSE, 0
17:51:48 WinSock: Connection Failed: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:51:48 LUA Processor: Connect Exception - Object reference not set to an instance of an object.
17:51:50 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
17:51:50 Aircraft Connection Started
17:51:50 Simconnect Version: 3.4.0.0
17:51:50 Aircraft FullName: Aerosoft CRJ-700
17:51:50 Synchronising Switches & Selectors .....
17:51:51 LvarNamesUpdated!
17:51:51 Creating Bespoke Vars
17:51:51 Bespoke Vars Created
17:51:51 Importing Bespoke Variables
17:51:51 Bespoke Vars Assigned, Importing Bespoke Events
17:51:51 Bespoke Events Temp Imported
17:51:51 Bespoke Events Imported
17:51:51 Loading Aircraft Settings
17:51:51 GetXMLConfigData
17:51:51 GotXMLConfigData
17:51:51 Loading Power
17:51:51 Loading MCPPRO
17:51:51 Loading EFIS
17:51:51 Loading P8
17:51:51 Loading T8
17:51:51 Loading RP48
17:51:51 Loading MESM
17:51:51 Loading WP6
17:51:51 Loading LGT
17:51:51 Loading LGT II
17:51:51 Loading GF46
17:51:51 Loading GF45
17:51:51 Loading TQ6
17:51:51 Loading DIO
17:51:51 Loading GF166
17:51:51 Loading SECM
17:51:51 Loading Joysticks
17:51:51 Clearing Displays
17:51:51 Reset Data
17:51:51 Aircraft Settings Loaded
17:51:51 Calling Aircraft Changed
17:51:51 Aircraft Changed
17:51:52 Synchronising Switches & Selectors Complete
Dennis
17:51:51 Loading P8
17:51:51 Loading T8
17:51:51 Reset Data
Appreciate your help as always.
Kind regards,
Dennis
hostname: localhost
port: 27015
path: default
luatimeout: 500
luahookcount: 3
However, I now have an FSUIPC connection error...see log below.
Any ideas what may be the cause of this one? Checked using netstat and no processes appear to be using port 8385.
17:17:01 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
17:17:01 SimConnect: Event Received: SIM, 1
17:17:01 SimConnect: Event Received: PAUSE, 0
17:17:03 WinSock: Connected To localhost On Port 27015!
17:17:03 LUA Processor: Started!
17:17:05 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
17:17:05 Aircraft Connection Started
17:17:05 Simconnect Version: 3.4.0.0
Many thanks Steve, your support is much appreciated as always!
