Detective Suggestions (button labelling, tooltips) and Device Tab assignment-contexts, Manual errata
edited November 2013 in Product Suggestions
Hi Stephen,
Coming back to things after a break, it struck me just how non-intuitive some of the language is on the Detective interface. I found I was completely at odds with the 'filter', '!filter' concept, because the word 'filter' all depends (in language terms), on which side of the fence you're sitting at the time! That is, when someone says 'filter this'... do they mean filter it IN, or filter it OUT? Unless you know what was in the developer's mind at the time, you've got a 50-50 chance of getting it right. And most often, from a 'user-searching-for-an-LVAR-activity' point of view, you're actually most interested in filtering-IN a certain LVAR, so (without RTFMing) you're almost certainly going to plump the wrong way! Thereafter, you'll have plenty of fun trying to work out what's going on (resorting to the manual only as an admission of defeat being the normal human way, of course!)
So - to that end, can I suggest that you rethink the labelling of the buttons in the filter to make them more obvious? Perhaps avoid the 'verb' references to filter entirely; instead, simple 'Show' (instead of !Filter) and Hide (instead of Filter) would be much better imho. Show All would replace !Filter All (I think, if I have the logic of that function right - and if not, well, you see my point about the confusion, I hope! :))
As for the buttons below, they'll make a lot more sense then, too. Obviously 'Filtered' would turn into 'Hidden', but it should be more intuitive that way.
I'm still not convinced 100% that removing the LVARs (or Events) from the selection list once they've been hidden from the Console output is entirely helpful - maybe better to mark it with its tick or a background change for that node? Not sure. It becomes most awkward if you're trying to detect an LVAR which turns out to be a set of inter-related LVARs that you want to study, because adding items to the 'Show' (!Filter) list if they're already removed from the selection list, becomes a tad awkward!
I'd also recommend a few tooltips on these buttons too, just so that they can be elaborated upon, especially if they're not referenced in the manuals yet. It took me a few moments to work out what 'SC Vars' was (presumably SimConnect?) though Bes Vars was easy enough. It would also enable you to remind folks that the Lvar and Event buttons are (as they always were) the 'display ALL' buttons (all lvars, all events), and not something else. I'd forgotten!
Moving back to the main window (MCP tab, in my case), can I beg that (if possible) impossible selections are removed from the relevant drop-down menus. Case in point, the Light Action dropdown, on the MCP; if it's referring to one of the buttons (say, the HDG HOLD button) then half the available selections on that dropdown are going to be red herrings, aren't they? I can't think of a way to use Divide as Decimal meaningfully with a 'Light Value' variable and a two-state green light! Maybe I'm missing something, though, so please enlighten me if I am! Conversely, one of the 'readout' displays (7-segment LED windows) is clearly going to use these kinds of math function, but may not use a simple 'ON' or 'OFF' (maybe they do, not sure)... but you get the distinction, I'm sure.
While I'm at it, there doesn't seem to be a way to make one of the two-state button-lamps show 'OFF' for -1, whilst showing 'ON' for +1, and any other value simply leaves the light in the state its already in (whether it be on or off at the time). I'm having fun with this bit, on the bus, with its push-pull rotary buttons! :)
I'm also having fun trying to work out how to recognise the 'long-push' button-state, and hook that up to a bespoke event (I have read both manuals several times, honest, but I think I'm getting snow-blindness or something, cos I really can't find it!)
Finally - I found a small error (I think) on P7 of the GIT manual: the reference to the shortnames for the Aerosoft Catalina. Looking closely one of the aircraft names has a dash in between the PBY and the 5, while the other has an underscore. In the following blurb, it says "we'd change the name to (dashed version which drops '_CIV' off the end)" and this would work because both airplanes have (underscored version) in their names; which clearly, they don't! I do understand the process being exemplified here, and I'm sure most will through trial and error, but the whole point of the example in the manual is to avoid T&E in the first place, so (unless I'm missing something very obscure) this one falls over, alas. Best get the examples right, or the users will have mucho fun working out WTF is going on! :)
Hope you understand these are all in the spirit of making a good thing better, and (hopefully) opening it up to a wider audience that isn't put off by its complexity. It is a complex tool, but (if I may make so bold) some aspects of it are further complicated because the concepts are either indistinctly handled, or confusingly worded, in the interface itself. That's going to frighten off the Johnny lightweights, I'm sure, but ultimately, you want everyone to be getting maximum use out of this wonderful tool; and it's quite possible to do that, I'm sure. It's swiss army knife of airplane control... just at the moment it's very easy to stab oneself in the knee! :)
All the best (and feel free to take issue with any of my presumptions, but just don't take offence, 'cos it's not meant in that way at all)
Neil
  • edited November -1
    Hi Neil,
    I agree its perhaps time to add some polish to the interface now all the hard stuff has been done.
    Happy to take on board the Detective comments. I'll take a look.
    Removing lvars is essential. On complex aircraft you are overwhelmed with data if you can't. I agree though it's a tad fiddly. I'll have a think about some alternative facilities.
    Lights and displays share the same base code and obviously display in the same part of the interface so not all commands are appropriate. I could of course apply some logic to filter out options, but these kind of nice things to do have been way down the list of priorities.
    The light issue may be a bug. If you use ON = 1 then any other value should turn it off. Perhaps the minus value is cancelling out the logic in my code. I'll take a look.
    The manual needs a complete rewrite. Roberto has sent me something as a starting point, but I haven't had time to review it as yet.
    Hi Neil,
    Just tested an lvar changing from 1 to -1 and it does turn off the LED, so the logic is OK (Light Action: ON, Light Value: 1).
    If the variable you are using is bespoke then this will be the problem because examining the code I have realised I'm not storing the previous values of these and so the comparison code always fails.
    The other thing that may be happening is that the lvar only briefly changes to -1 and returns to something else. This happens so quickly that it isn't picked up by Detective (sample rate is 4 times a second).
