GF-45 (X-plane 11)
Hi All,
In the setting tab with 45R I see 8 options.
What is the meaning of those options as i have only 2 rotaries?
I managed to get 1 rotary working but the manual is only generic and is not specific for GF-45.
Thanks!
  • You can assign multiple configs to GF45 and then assign the button of another GoFlight device the Event GF45_KEY_DEVICE where is the Device ID of the GF45 unit concerned. Pressing this button will cycle the configs.
    steve
  • edited October 2017
    Thanks Steve!
    Indeed want to have a button on my GF-P8 to cycle through the configs which i setup.
    I now installed version 2.0. What i discovered till now is the following:
    1. I setup the first option on the GF45 display. i.e. IAS speed.
    2. Then i setup the second option to display the Heading
    3. When i clicked on option one again it was not saved.
    4. I exported the xml and IAS speed setting was dissappeared
    Any clue what i am doing wrong here?
    Running X-Plane 11, Windows 7 Ultimate
    Thanks again
  • Sounds like a bug. I'll investigate.
    I reset the config and reloaded the xml and it works. Will do some more testing and feedback the info to you. Also I assigned a button on the P8 to cycle and that triggers the right setup.
    Let me know if you need something!
  • Just one little question:
    How can i set the display on the GF45 to NOT display decimals behind the dot. So i.e. 218 and not 218.39 for speed or heading?
  • I have just tested with the FSX and X-Plane versions and everything I selected was stored OK. Can you give me the steps to re-create the problem?
  • Thanks! for the decimal stuff.
    I reprogrammed it and works fine now. Try to do a test in the afternoon and if i found something will sent it to you.
  • Understand the ROUND light action but i see that only with the GF-P8 and not with the GF-45 (45O).
    By the way... the P8 has only a Led per push button ;-)
  • You are right, it isn't available. I'll add it into GIT.
  • New version is up that had added Light Action support to the GF45.
  • Thanks Steve!
    I uploaded a complete config for the 737-800 and working now on the A320NEO from Jardesign...
