GIT 2.0 Sometimes hanging
Hi All,
I am now setting up JARdesign A320NEO on GF45 and GF-P8. I will share this setup when i have finished it. In setting up I experience often hanging of the GF module and especially the rotaries.
When i test it via the "Test Bespoke Event" the programmed BES are working.
I have programmed the default 737-800 too and didn't have this issue.
Is there a way to monitor or trace any error. The log isn't saying very much other then "GF45: The given key was not present in the dictionary."...
  • When does the hang occur (assignment to the device, using the hardware etc.)?
    What i did is the following. Started with a Barometer function
    1. Made two BES events, BARO_PLUS and BARO_MIN
    2. In these events i added the custom detective (jd/ind_baro_hpa +=1) and of course -=1 for the MIN function.
    3. Added the BES to the rotary
    4. In the display show the BARO reading
    Now is the display still working but the rotaries refuse to work. Also when i program them with other example function.
    I got also a lot of error messages in the log. Don't know
    Just a minute ago i wanted to start monitoring and Xplane crashed. So I think the A320NEO is to specific and not easy to use with the GF modules.
    But will investigate this further and let you know.
    Andre
  • To add, saw that i accidentally removed the two LUA BES events from the list. Can that be the problem?
  • I have just uploaded a new version that fixes this issue.
  • Thanks Steve, have a nice weekend!
