Registration User Key
Unable to paste user key in license registration interface.
Robert
Disregard...Problem solved
  • I have the same problem. . I pick up the key, but I'm mistaken "203 invalid details."
    Can you please tell me how did you solve it?
    Thank you.
    vincenzo.mariconda@gmail.com
  • Make sure you have no spaces at the beginning or end of the key.
  • I have had to make more than 10 reinstalacions of P3d v4 for technical problems and therefore I had to reinstall GoFligt Interface Tool also more than 10 times and when entering the Use key it answers "Registration failed - 202 Exceed Install Cou". If I ask for a new key with the "i" in the lower left corner of the box, entering this new Use key indicates "Registration failed - 203 Invalid Order". How can I get a new valid key?
  • Your install count has been reset.
  • Many thanks. Use key now works perfectly.
  • The same occurs to me
    How can I register
    Tanks
  • ckdo93,
    I have reset your install count, please try again.
    How can I register
    Tanks
  • Poecke1,
    What error message are you getting?
  • That doesn't make sense as your install count is zero. Are your sure its 202?
  • Sorry Steve it works fine now thanks for your support
  • hi Steve sent a ticket I have the same problem
  • Hi Lowdown,
    I have reset your install count.
  • Thanks Steve
  • edited October 2018
    hi, iam traying to install my GIT with the password ******** in my account profile but is does not working. showed this error: registration failed! 203 invalid details.
    . iam a new usser. trying with this drivers for GOFLIGHT for xplain 11 win 10
    tks for your help
  • That User Key is not correct. The User Key is a very long key available in your account profile. Please see the last entry here called "Where is my User Key and/or software download?" here: https://www.pollypotsoftware.org.uk/support/need-assistance.html
  • hi Steve,
    I hope you feel better
    I have the same key problem as other members and only for P3D, can you do the same manipulation so that I can open the GIT with de last version
    thanks
    Roland
  • I have the same problem.I have had to make more than 15 reinstalacions of P3d v4 and for X-Plane for technical problems and therefore I had to reinstall GoFligt Interface Tool also more than 15 times and when entering the Use key it answers "Registration failed - 202 Exceed Install Cou". Upgrade my PC with a NEW very better because crashed hard disk. How can I get a new valid key?
    Thank you.
  • I have reset your install count.
  • I have the same issue. Please reset my account. Thanks Bob
  • Gents, please use the enquiry form for these issues as I will respond outside normal working hours for a speedier response! It will be done in 5 minutes Bob.
This discussion has been closed.
