Problems with START functionality in 64 bit GIT
HI Steve,
Ive set up a series of START functions for a particular aircraft in 32bit GIT and P3Dv3.
START contains a CALL to an INIT BESEvent (which sets inital values for BESVars), then after a label, makes multiple CALLs to other BESEvents which interact with the sim's events and lvars, sleeps, and then loops back to the label to repeat over and over.
This worked really well, and I was able to make the Boeing style GoFlight MCP PRO act like an Airbus FCU.
Now that my airbus is available in 64 bit P3D, the same functions dont seem to work the same in 64bit GIT.
The lvars and events in the aircraft have not changed between 32 and 64 bit, but the functionality of how START seems to work looks like it has.
I havent been able to track down exactly what the difference is, but its almost as if either only one CALL in the sequence is ever executed, or, its not looping back after the Sleep.
Any ideas why I am seeing a difference between the 64 bit and 32 bit GIT?
It goes something like like
START
sleep 50
Call START-INIT
:LOOP
Call START-FCU-SPEED
CALL START-FCU-HDG
CALL START-FCU-VS
CALL START-COMMS
Sleep 1
Goto LOOP
None of the other START named functions contain loops
  • The GIT front end is still the same 32bit version, only the backend dll is 64bit.
    I have just checked the change log and nothing has been done on bespoke event processing and calling. If the same code works in GIT with P3Dv3 and the GIT versions are the same, I think it may be suggesting an issue with the 64bit version of the aircraft.
    Have you ran the Bespoke Events in Detective via the Test button and see if they work as you expect in P3Dv4?
  • I have tried each one individually and they seem to work.
    Could it be that one of the commands Im using in one of the START-* functions is failing, and therefore stops the START routine from being able to loop?
    In one of the START- functions, Im using a ReadMemSB call
    BES-TXPDR-MODE-C = ReadMemSB(7b91)
    Does ReadMemSB work the same in Git64, and is the offset value still valid and correct between 32 & 64 bit P3D?
    (That offset value is not aircraft specific, but a value used by VATSIM's vPilot app)
  • If any task fails you would see an error message in the GIT Log tab - have you checked?
    I don't think Pete Dowson has changed the memory values in FSUIPC 64bit, but it may be worth double checking.
    I'll do some testing at my end and see if I can spot anything.
    Some further debugging has shown that if I remove the ReadMemSB call, then START loop works without breaking/stopping.
    The GIT log shows this entry on start of GIT, which I'm not sure if this is relevant or not:
    FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
    Registered FSUIPC5 is running successfully. I dont have any firewalls running, and both GIT and P3Dv4 are started as Administrator.
    This code worked without issue on P3Dv3/ GIT32 with or without vPilot running.
  • In the FSUIPC Modules directory you should find a file called ipcinit.lua. Can you check it contains the line "ipc.runlua("gitlua");". Also check the modules directory contains the file gitlua.lua.
  • edited November 2017
    File ipcinit.lua is in the modules directory, together with FSUIPC. It does contain the line
    ipc.runlua("gitlua"); (only quotes around gitlua)
    The modules directory does also contain the file gitlua.lua
    fsuipc5.ini also contains a section called
    [LuaFiles]
    with 4 lines underneath, numbered1-4, with gitlua being listed against 1
    fsuipc5.log file contains this, which may be of interest....
    14991 LUA.0: beginning "D:\P3Dv4\Prepar3D v4\Modules\ipcInit.lua"
    15085 *** LUA Error: D:\P3Dv4\Prepar3D v4\Modules\gitlua.lua:5: module 'socket' not found:
    no field package.preload['socket']socket
    no file 'D:\P3Dv4\Prepar3D v4\modules\socket.lua'
    no file 'D:\P3Dv4\Prepar3D v4\modules\socket\init.lua'
    no file 'D:\P3Dv4\Prepar3D v4\modules\lua\socket.lua'
    no file 'D:\P3Dv4\Prepar3D v4\modules\lua\socket\init.lua'
    no file 'D:\P3Dv4\Prepar3D v4\modules\lua\socket.dll'
    no file 'D:\P3Dv4\Prepar3D v4\modules\lua\loadall.dll'
    67174 LUA.0: beginning "D:\P3Dv4\Prepar3D v4\Modules\ipcReady.lua"
    67267 *** LUA Error: D:\P3Dv4\Prepar3D v4\Modules\SLX_G1000.lua:28: ')' expected (to close '(' at line 27) near 'else'
    Version of FSUIPC5 is 5.121b (2nd October 2017)
  • It looks like Pete can't implement tcp socket support in FSUIPC 5, so GIT can't communicate with it anymore. See http://forum.simflight.com/topic/83771-lua-socket-64-fsuipc-5/
    The work around mentioned may work.
  • Oh no - that's put a REAL spanner in the works....
    I am licensed for WideFS, which I see mentioned might work, although I'm not sure what I would have to install where, and configure how, to get WideFS Client to support your GITLUA script.
    I can assist and try it out, if you can make some sense of what's being discussed in that link.
  • See this thread and copy the 2 lua files I mentioned into the wide client directory: http://forum.simflight.com/topic/76651-wideclient-lua-script/
    I was able to get this working via the link above.
