having problem where my bespokeevents.xml and variable.xml are resetting
This has happened twice now in the past few days. I mapped all my devices to the aerosoft crj that I created and got some kind of error when loading it and now my bespoke.xml files are blank. Thus I have to map all my devices again to the commands I created. This may have happened after I tried again to import my backup for q400 that I had in p3d v3. I'm not sure if that's related or not. I'm getting annoyed with redoing stuff over and over again.
thanks for any help you can provide
  • as a followup, what I mean is now as an example my T8 mappings are all gone. the events I created are still listed ( I did export them to another folder and the files are now called aerosoft crj-700 Vars.xml and Aerosoft CRJ-700.xml and I can import those back in, but the actual mapping to my devices is gone. thanks
  • What version of GIT are you running?
  • was using 3.4.1. Just realized there is a new version and just installed. Seems like there were a lot of fixes in it, so hopefully that resolves my issue.
  • Hi Bill,
    I have hardened the code that does the saving. Its only in the X-Plane version at the moment, but it will be added to the other versions this week.
