How do you use the tool
Hi sorry for the thick question i am totally stumped on how to use the tool.
I can successfully get three greens in the status window of the application.
I am looking to setup my mcp pro for PMDG 777 and Aerosoft A320 extended
Is there a real idiots guide to this or a sample configuration i can look at
My PMDG 737 and 747 work fine
thanks in advance
  • edited November -1
    Once PMDG release the Software Development Kit for the 777, GIT will provide built in support for it. In the meantime you may be able to configure some functions but I haven't tried.
    I know many people have had great success with setting up for the Aerosoft A320, perhaps someone would share their config files with you (hey guys can you help here?!)
    In the meantime a couple of pointers:
    -You cannot access any config tabs until you are in the VC of the aircraft.
    -FSX needs a small backend dll to be loaded - instructions in the Beta user guide.
    -All devices are disabled by default so you need to enable them.
    -If the aircraft are standard i.e. use simconnect/fsx standards then using the FS Default buttons will automatically configure some devices to work without you doing anything. Using FS Default and then looking at the resulting configuration will help you to understand what to do.
    -For non standard aircraft (which these days means most of them) you have to use Detective to build Bespoke Events. An example of how to do this is given in the Beta user guide. If you have any of the aircraft listed on the download page , I strongly suggest you use those first, so that you can download the configs and get a feel for how things work.
    I intend to write a new user guide and provide some tutorial videos soon.
    thanks for the update.
    I can get the tool working fine and enable the MCP Pro i just have no clue what i need to select at that point.
    Is there a link for the downloads page?
    the download page is not working seems to show apache error
    Download page is working OK now.
