Functionality for GF-45 with GF-P8 in the Past
in FSX (and P3Dv3) times I used the GF Config to setup the GF-45 to Display the Autopilot and the VORs, DME, Frequenties. With the GF-P8. I programmed the buttons to switch the GF-45 from Autopilot to Nav1, Nav2 and the DMEs. I pressed a button at the GF-P8 and the GF-45 showed the Nav1 or 2. With the rotaries of the GF-45 I changed the Frequencies of the Nav 1 or 2.
The setup in the GF-Config2 Tool was quite simple. Now in X-Plane 11 I want to have this functions back. Would it be possible that this will be a standard setup in GIT?
This would be great!
Martin
  • Hi Martin,
    You can configure GIT to do this. It can take upto 8 different configs and you assign the Event GF45_KEY_DEVICE1 to the P8 for cycling through them.
    I'm sure this is possible. Could you give me an instruction which events I have to setup therefore? This is my biggest problem.
    Martin
