Flight Factor 777 in X-Plane 11 (Beta)
should the Bespoke Events from the download section work with the FF 777? I imported them with the wizzard and the MCP-Pro doesn't work.
Martin
  • As far as I know. You need the version of GIT I uploaded last night though as it fixes a major bug in command detection.
  • I'm using GIT 2.0.7.0 which I downloaded today. I use the FF 777 v. 1.9.9. with X-Plane 11.10 b7. I import the Zip file from the download section and after loading the MCP Pro and EFIS doesn't work. Altitude at the MCP-Pro shows "0" and the rotaries don't work.
    Could someone check this?
    Martin
  • I have just tested and there are at least 2 bugs causing problems in GIT. One I have fixed, the other will have to wait until tomorrow. I'll try and get a fix out tomorrow.
  • Ok, maybe this last missing fix is causing this problem? I also tried deleting the GIT folder in documents an reimporting the Zip file - without luck. The MCP Pro shows "0" at Alt and Hdg.
    Does it work for you or somebody else?
    Martin
  • It doesn't work with the newer versions of GIT. It will by the end of play today though.
  • New version of GIT available that makes the FF 777 config file work in XP10 and XP11.
  • Hello Steve,
    now it works! Great! :)
    Many thanks for your great support!
    Best wishes,
    Martin
