EFIS range PMDG v1.2.6
Hi Steve
Just thought I'd let you know about the anomalies with the EFIS range settings in 1.2.6. I have two EFIS modules.
Pilot:
10-640 ticked - range on NGX VC display = 5-320
10-640 unticked -range on NGX VC display = 5-320
Copilot:
10-640 ticked - range on NGX VC display = 2.5-180
10-640 unticked - range on NGX VC display = 1.25 - 80
Paul
Hi Paul,
I can't replicate what you are seeing at all.
Does anyone else have this problem?
Hi Steve
Re-checked last night and it is still the same. It's no problem at all just thought you'd like to know.
Second issue I'm now having is with the MESM. As you may remember I had a replacement unit sent from GF.
Now using GF v2.22 & PMDG 1.2.6 I sometimes have a problem with the RH rotary as follows.
1. load GF NGX profile, only GF166's are assigned, all others blank
2. start FSX
3. load an NGX plane
4. start NGX interface.
At this point functions of MESM work perfect. (acft on gnd power)
5. start APU, put on APU power and programme the FMC. Now the RH engine start rotary has fallen asleep and will not respond on the OH panel. LH start and ignition switch selection work fine.
6. restart NGX interface and RH rotary comes back to life.
7. at the end of the flight recheck the MESM, out of curiosity, and the RH rotary has gone to sleep again.
Do I need to change any of the delay sliders, or check the multitask box?
Paul
Hi Paul,
I'll check if I can reproduce this over the weekend.
Hi Paul,
When it goes to sleep, can you bring up the status tab of the Interface and monitor the Goflight LED to see if it flashes when you turn the selector.
OK, but can you do the led test for me and also check that the synchronising switches and selectors stage completes (it shows up in the Log tab).
I asked you to do this in a prior post:
Hi Paul,
Yes I understand the situation, but I need you to recreate the condition where it does go to sleep so you can do the led test as stated above.
No Paul. I have done one long haul flight to test and couldn't recreate the problem as yet. I need to find some flying time to have another go.
ok thanks, not a big issue at all just curious.
Paul
Hi Paul,
Are you using Windows 8?
