Crash when selecting SimConnect Events and LVAR monitoring
I am using the A2A Cessena 182. When I try to select a simconnect value for a switch on any panel from MCP to GF Switch/Button to LGT2 GIT tool crashes instantly. I am in Prepar3d V4.1. I have tried everything and still get the same response.
Additionally the LVAR monitoring instantly crashes GIT. I set the refresh rate to the lowest and it still has the same problem. I know there are a lot of LVARs with the A2A but about a month ago I had no issues at all when using the detective and the Commanche 250.
Brian
Brian
Nothing else is changed. I have although installed Prepar3D V.4.1
I uninstalled all GIT and GoFlightConfig to see if issues keep happening. Reinstalled and still have the same issues. Simconnect choices will not crash every time but if I program 2 or 3 switches without closing and reopening it will crash on the second or third one. It will do it with my custom bespoke events as well. I noticed this recently. As soon as I choose the event/action from the drop down it locks up and crashes. Which is frustrating b/c I notice if you don't close the program before a crash you lose all data created before a proper shut down. Including bespoke events.
The LVAR monitoring straight crashes GIT as soon as you turn it on. If I run SPAD.next and do LVAR monitoring I have no issues.
I will get a new release out asap.
Brian
