CTD after Edit of Switch statement
To replicate:
1. Bring up Detective
2. Create a bespoke using a Switch, Case, EndSwitch (2 cases)
3. Copy current Bespoke
4. Edit Switch line, new Switch line is created based on the current Lvar (not sure if this was intended, expected to just change the Lvar reference in the Switch statement)?
5. Search for existing Lvars
6. Set to a value
7. Hit Check ... this is where I got the CTD
Application: GoFlight Interface Tool P3Dv4.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.NullReferenceException
at DynamicClass.(System.Object)
at A..(System.Object)
at A.A.App_DispatcherUnhandledException(System.Object, System.Windows.Threading.DispatcherUnhandledExceptionEventArgs)
at System.Windows.Threading.Dispatcher.CatchException(System.Exception)
at System.Windows.Threading.Dispatcher.CatchExceptionStatic(System.Object, System.Exception)
at System.Windows.Threading.ExceptionWrapper.CatchException(System.Object, System.Exception, System.Delegate)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
at System.Windows.Threading.Dispatcher.PushFrame(System.Windows.Threading.DispatcherFrame)
at System.Windows.Application.RunDispatcher(System.Object)
at System.Windows.Application.RunInternal(System.Windows.Window)
at System.Windows.Application.Run(System.Windows.Window)
at A.
.(System.Object)
at A.A.I()
In addition, I noticed that a bespoke rename caused a duplication in the list when assigning to ON in my RP48B. And the list didn't sort correctly with some of my "_" (underscore) at the top (correct) and some "_" at the end of the list (not correct). My expectation was that the list would be updated and sorted whever a new bespoke is added. This is with 3.4.8.0 GIT for P3DV4.
Cheers, Rob.
  • Hi Rob,
    I have tracked down and fixed the CTD / duplicate Switch task issue. I'm looking at the other issues before getting a new release out.
  • Thanks Steve, I love the Switch/Case construct, use it A LOT. Overall as you keep improving functionality my workflow improves, really appreciate how you're evolving the product lines.
    Cheers, Rob.
  • Hi Rob,
    New version is up. I have done nothing on the renaming problem as I couldn't re-create the issue.
  • Thanks Steve, will give it a test tonight.
    I'll see if I can be more accurate with steps to replicate renaming issue, actually think it's just a "refresh" on the actual button/control dropdowns (i.e. P8, T8, etc.) after a rename is performed in Detective (I see duplicate entries at the bottom of the list). Detective shows the rename correctly in it's dropdown (no duplicate).
    A video might be the best approach showing you what happens.
    Cheers, Rob.
  • I wonder if its obfuscation of the final release that is messing it up as my dev version worked fine. I will check tomorrow.
    Testing out 3.4.9.0 ... when I add a Bespoke, type in name (i.e. _DHC3_LIGHTS_INSTRUMENT_ON) and click on the Check button I get a CTD with the following error in the Event Log:
    at A..
    (System.Object)
    at A.O.App_DispatcherUnhandledException(System.Object, System.Windows.Threading.DispatcherUnhandledExceptionEventArgs)
    at A..
    (System.Object)
    at A.O.G()
    Here is a video (unlisted) of the CTD: https://youtu.be/mZp86U73buU
    Cheers, Rob.
  • Hi Rob,
    It was the new sorting code causing the problem so I have removed it and released a new version. I'll take another look at the sort issue next week.
  • Sorting as in the view sorts? I really like those new views and the ability to left double click to auto search Lvar and right click to remove current Lvar ... massive time saver.
    Will try 3.4.10.0 tonight.
    Cheers, Rob.
  • No, its the sorting of the Combo boxes in the config tabs. The Detective views have stayed.
  • Confused, sorting in the bespoke combo in Detective ... after I clicked the check (to add) button (per my video)?
  • Its been removed in the config tabs of the devices.
  • Hi Steve, I seemed to have reached my download limit? Any chance you can reset this so I can test?
    Cheers, Rob.
  • Hi Steve, 3.4.10.0 is working well, no major issues so far.
    Really like those new views and the ability just right click to hide and left double click to set the Lvar ... my workflow is so much more efficient now.
    One quick question, when I export modules and/or bespoke to file, it always defaults to Document folder, is there any way to define the folder to default the saving of export files?
    Cheers, Rob.
  • Its currently hard coded. I'll look at providing an option for it.
  • Thanks Steve!
    Cheers, Rob.
