CTD after Edit of Switch statement
To replicate:
1. Bring up Detective
2. Create a bespoke using a Switch, Case, EndSwitch (2 cases)
3. Copy current Bespoke
4. Edit Switch line, new Switch line is created based on the current Lvar (not sure if this was intended, expected to just change the Lvar reference in the Switch statement)?
5. Search for existing Lvars
6. Set to a value
7. Hit Check ... this is where I got the CTD
Application: GoFlight Interface Tool P3Dv4.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.NullReferenceException
at DynamicClass.(System.Object)
at A..(System.Object)
at A.A.App_DispatcherUnhandledException(System.Object, System.Windows.Threading.DispatcherUnhandledExceptionEventArgs)
at System.Windows.Threading.Dispatcher.CatchException(System.Exception)
at System.Windows.Threading.Dispatcher.CatchExceptionStatic(System.Object, System.Exception)
at System.Windows.Threading.ExceptionWrapper.CatchException(System.Object, System.Exception, System.Delegate)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
at System.Windows.Threading.Dispatcher.PushFrame(System.Windows.Threading.DispatcherFrame)
at System.Windows.Application.RunDispatcher(System.Object)
at System.Windows.Application.RunInternal(System.Windows.Window)
at System.Windows.Application.Run(System.Windows.Window)
at A.
.(System.Object)
at A.A.I()
In addition, I noticed that a bespoke rename caused a duplication in the list when assigning to ON in my RP48B. And the list didn't sort correctly with some of my "_" (underscore) at the top (correct) and some "_" at the end of the list (not correct). My expectation was that the list would be updated and sorted whever a new bespoke is added. This is with 3.4.8.0 GIT for P3DV4.
Cheers, Rob.
To replicate:
6. Set to a value
at A.
.(System.Object)
at A.A.I()
Cheers, Rob.
I have tracked down and fixed the CTD / duplicate Switch task issue. I'm looking at the other issues before getting a new release out.
Cheers, Rob.
New version is up. I have done nothing on the renaming problem as I couldn't re-create the issue.
I'll see if I can be more accurate with steps to replicate renaming issue, actually think it's just a "refresh" on the actual button/control dropdowns (i.e. P8, T8, etc.) after a rename is performed in Detective (I see duplicate entries at the bottom of the list). Detective shows the rename correctly in it's dropdown (no duplicate).
A video might be the best approach showing you what happens.
Cheers, Rob.
Testing out 3.4.9.0 ... when I add a Bespoke, type in name (i.e. _DHC3_LIGHTS_INSTRUMENT_ON) and click on the Check button I get a CTD with the following error in the Event Log:
at A..
(System.Object)
at A.O.App_DispatcherUnhandledException(System.Object, System.Windows.Threading.DispatcherUnhandledExceptionEventArgs)
at A..
(System.Object)
at A.O.G()
Here is a video (unlisted) of the CTD:
Cheers, Rob.
It was the new sorting code causing the problem so I have removed it and released a new version. I'll take another look at the sort issue next week.
Will try 3.4.10.0 tonight.
Cheers, Rob.
Cheers, Rob.
Really like those new views and the ability just right click to hide and left double click to set the Lvar ... my workflow is so much more efficient now.
One quick question, when I export modules and/or bespoke to file, it always defaults to Document folder, is there any way to define the folder to default the saving of export files?
Cheers, Rob.
Cheers, Rob.
