GIT 3.4.10.0, P3D v4.1.7.22841 and A2A Simulations C172 Trainer.
Not sure what I'm doing wrong here but the GIT works without issue with the PMDG 737NGX, however when I load the A2A Simulations C172 trainer none of the GoFlight module tabs are active, as with Aircraft Power, DIO, Detective and LUA. The only active tabs are Status, Settings and Log.
My connected modules are listed in the GoFlight group, the Simconnect light is yellow (not a concern), and the Aircraft group has the mode as Generic then underneath A2A_C172.
I'm trying to use the LGT II module for the Aileron, Elevator and Rudder trims, but the Import Wizard and Detective buttons are greyed out.
Any assistance appreciated.
Cheers
Graham McAllister
Cheers
Graham McAllister
You need to be in the Virtual Cockpit before they become enabled. If that still doesn't work, it sounds like the GIT dll is not loading so try reinstalling GIT.
I'm in the virtualm cockpit, although I now have my suspicions my problem may have to do with my VC being a view with Chase Plane.
I have reinstalled GIT, bu to no avail.
Is Chase Plane likely to be the issue?
Cheers
Graham
