MCP - HDG/CRS rotation speeds
Goflight MCP - XP11 - Laminar Baron B58
Rotating the MCP heading or course selector is a slow process under the FS default MCP config - especially all the way thru 180deg.
Is there a method that can be applied to manage a two step rotation speed to reduce the time spent winding the bug thru large changes ?
* Rotate fast = 10deg increments
* Rotate slow = 1deg increments
Thanks in advance,
Brett
Thanks in advance,
Brett
Can you check the Event Action is set to ROTATE for the clockwise and anti-clockwise events.
Yes, the MCP Heading event action is set to rotate for both the clockwise and anti clockwise events, but there is no ability to increase the speed of rotation, which is what I am after.
I wondered if you could apply a bespoke event that may provide a two-step rotational speed selection for both the HDG and Nav1-Nav2 CRS selector.
Brett
If that still isn't good enough, you would need two bespoke events for the heading change which would add or subtract 10 degrees from the dataref "sim/cockpit/autopilot/heading_mag".
It appears that Laminar have not yet had the time to include a fix, however the coding of a simple Lua script plugin by a XP.org member (see post dated 10Jan18) may have merit - albeit not specifically designed for GoFlight equipment.
I have not attempted to install the plugin as yet, as I am unsure how what effect it may have on the stability of GIT, but I would appreciate your thoughts before heading down that path.
Thx Brett
Are Commands being used on the rotary or is it a Bespoke Event that's updating a dataref?
Additional Lua scripts for airspeed, altitude, elev_trim, ops and vertspeed are located in a zipped folder at the X-Plane.org link in my previous post.
Thx Brett
dataref("TIME", "sim/time/total_running_time_sec")
--dataref("HDG_AP", "sim/cockpit/autopilot/heading", "writable")
--How many degrees should the trim jump each time if your spinning fast?
local FastDegreesHDG = 12
local StandardDegreesHDG = 1
--How many spins per second (or button presses per second) is considered FAST?
local HDGFastTurnsPerSecond = 3
local TresholdTime=0.4
--You shouldnt need to change anything below-----------------------------------
--HDGTurnTimes is used to store times since each turn
HDGTurnTimes = {}
HDGNumberUpTurns = 1
HDGNumberDownTurns = 1
local i = 1
for i = 1, HDGFastTurnsPerSecond do
HDGTurnTimes[i]=1
end
function HDGIncrement()
local hdg
hdg=get("sim/cockpit/autopilot/heading")
local TimeNow = TIME
HDGTurnTimes[HDGNumberUpTurns] = TimeNow
local i = 1
local ItsFast = 1
if (HDGTurnTimes[i] + TresholdTime >= TimeNow) and (ItsFast == 1) then
ItsFast = 1
else
ItsFast = 0
end
end
HDGNumberUpTurns = HDGNumberUpTurns + 1
if HDGNumberUpTurns > HDGFastTurnsPerSecond then
end
if ItsFast == 1 then
hdg=hdg+FastDegreesHDG
else
hdg=hdg+StandardDegreesHDG
end
set("sim/cockpit/autopilot/heading",hdg % 360)
end
function HDGDecrement()
local hdg
print (hdg)
HDGTurnTimes[HDGNumberDownTurns] = TimeNow
local i = 1
local ItsFast = 1
ItsFast = 1
else
ItsFast = 0
end
end
HDGNumberDownTurns = HDGNumberDownTurns + 1
if HDGNumberDownTurns > HDGFastTurnsPerSecond then
end
hdg=hdg-FastDegreesHDG
else
hdg=hdg-StandardDegreesHDG
end
end
create_command("FlyWithLua/HDG_UP","This command moves HDG bug up","HDGIncrement()", " ", "")
create_command("FlyWithLua/HDG_DOWN","This command moves HDG bug down","HDGDecrement()", " ", "")
I am using the standard GIT Baron 58 config.
Brett
Hdg Increase Lua File: Hdg Decrease Lua File: Best wishes
