Installation
Trying to install following the different step however with no success
Hre is my dll.xml file.
Is everything ok because I didn't received the message below.
5) Start FSX or Prepar3D and ensure you receive a Microsoft Flight Simulator Security Warning about loading "Goflight Interface Module.dll". Click Run, followed by Yes. If you do not get this warning, you have made a mistake in the dll.xml file and need to repeat step 3 making sure you have the correct directory.
If its still not working, copy and paste the log from the Log tab in GIT and tell me what the LED's are on the status tab. Also tell me if the Detective button is enabled.
You need to pick a device from the drop down list and configure; see https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git.html
The whole manual is here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git.html
Yes it seems that the connexion works. Thank you.
However I read the support file in order to setup the GF166
I just want to configure my GF 166 for using as NAV 1 and Nav 2.
Means that I want that the center button switch the sby freq as activ ...
The left button switch to NAv 1 and the right button switch to nav 2 ...
I'm nearly there but when I switch the sby freq to activ ... the system also switch the radio freq sby to activ but I only want to have action on NAV not on radio ...
Attached you ll find my GIT ...
I configure the GF166 with the shortcut NAV.
I also notice that the GF166 seems to be inactiv after around 30 min means no more action is allowed on it.
Make sure you have everything disabled in GFConfig for the GF166 as I noticed from a previous picture, you had it configured.
If GFConfig and GIT are both configured for a particular device, strange things will happen.
Ys everything works well ...
I will probably buy the Nav Data Tool ... the datas are up to date ?
Thanks a lot for your kind support, the GIT is very great and I wish you a merry Christmas.
Hervé
