bespoke variables
Hi, I'm trying to configure Concorde X by FSLabs to be used with a bunch GoFlight modules (switches, rotaries, radios, etc) via the interface tool and I got a lot done so far (amazing piece of software btw). I've looked on the manual and on the forums but couldn't find a way to create bespoke variables, is there a way to do that? Any help would be greatly appreciated, thanks!
  • edited November -1
    Take a look at the picture here:
    in the Variables Area, there is a button called Bes Vars. Click on this and you will see them all listed. You can rename them as well by entering a name in the text area and clicking Rename.
    Thanks for the quick response. Ok I've managed to rename one the bes vars shown on the variables area, but how can I edit it so it "does" things (display a label, divide by an integer, etc)? Can they be edited just like bespoke events or do they work differently?
    You can use them in two ways:
    -Assign them in the various device configuration tabs as LED or Display data.
    -Create a Bespoke Event and use various tasks on them such as Set+, If, If Var, Set etc.
    Thanks very much Steve!
