A/T does not stay engaged
Hi there, I am using pollypots software as an interface between Goflight MCP Pro panel and PMDG NGX 737. Everything works perfectly with one very annoying exception. The A/T will not stay engaged. When the physical switch is put into ON position, it is recognised by PMDG and flicks momentarily into ON position, but then immediately flicks into OFF position. If I use the mouse to engage A/T, then it stays on as required. Any help will be greatly appreciated. Many tnx in advance and kind regards. Alex.
If the A/T switch is not staying engaged in the VC then you have not configured the aircraft correctly for A/T use (programmed the FMC and setup up the MCP etc). Its not a GIT or MCP PRO issue.
Test your switch with GoFlights test software here: https://www.dropbox.com/s/n1hw4huebtuwgqz/MCPProChkA25.zip?dl=0
PS: You could try renaming Documents\GoFlight Interface Tool so that GIT starts with a blank config and see what happens when you re-enable the MCP PRO.
