Interface tool causing to have to uninstall PMDG 737
When the Interface tool was just in Beta a while back i paid Steve to come in my rig with Team View and set up my PMDG NGX 737 in FSX and it worked flawlessly till now and as far as i know i didn't change anything .Then one day when as i always let the 737 countdown to zero before i touch anything the sec i hit a function with the mouse light switch, FMC it don't make any difference all of a sudden the Landing gear lever started oscillating in and out and making a repeated Beep Beep sound. In the air the magenta coloured speed box goes up and down in sync with the landing going in and out .I tried everything , searched the net, forums, and no answer . So i UNinstalled the PMDG 737 completely and reinstall it and all was ok till yesterday again . I had put a post on Avim --PMDG specific to Ngx 737 about this problem -you can go look if you like, and low and behold one fella answered me to say that the same problem happened to his friend and it was linked to the interface tool and he had to uninstall and reinstall
the NGX also , if he had the beta or paid version i don't know. So i'm gonna fly the 737 like this till i get a proper answer what to do cause i'm thinking of getting the 777 and Steve told me i would have to buy the interface tool if i want to program the 777 and 737 together.I hope i explained the problem well enough and you're welcome to come in my rig like before to have a look i just have FSX only -- Thanks Louis
If a reinstall of the NGX fixed the problem, then the problem was with the NGX and not with GIT.
If you are running the very old donation-ware version of GIT then you will need to buy GIT to get PMDG 777 and 747 QoS II compatibility.
