Compatibility with SPADNext?
You might recall an issue I had in July which in some way righted itself after reinstalling all manner of software:
https://www.pollypotsoftware.org.uk/vanillaforums/discussion/670/why-is-my-mcp-pro-adjusting-all-dialed-inputs-in-increments-of-threes#lates.
Since then, I've moved house, been busy at work and so not had much time to get back to simming. I now have time since a couple of weeks and decided however to fresh install everything from Windows 10 (64bit) to all of my sim software. Yet again, after many hours of looking at this forum, Avsim, etc etc.., I have the same issue as July! I have the latest GoFlight drivers, GIT version 3.4.1, latest PMDG 737NGX (fresh download), latest P3D v4.0.28.21686. I can't help, but wonder if there is some conflict with SPADNext? Please advise - thanks.
In the mean time, you could create a lua file containing:
sendevt("EVT_CTRL_ACCELERATION_DISABLE", MOUSE_LEFTSINGLE)
and then run it when the problem arises in the NGX to see if it fixes the issue.
Still having a frustrating time here! I have sent the following message to SPADNext in hope of a sensible solution. For reference, I believe that the issue is certainly caused by SPADNext, not the GIT. I only wish there was a way in which I could either get SPADNext to completely ignore my GoFlight kit OR, find another software to manage my radios and Switch Panel. Just a thought, but I wondered if you might have any suggestions? GIT does exactly what it should do until I start up SPADNext! I've attached log files that might help.
Message to SPADNext:
I have uninstalled and reinstalled my flight s sim and all other software countless times since last October and always end up with the same issue, which seems to be that SPADNext totally screws with my MCP Pro. Having started the sim, loaded and initialised PMDG 737, started the GoFlight interface, everything is fine. Then, when I start SPADNext, it totally screws up the MCP Pro! I've researched, looked at your site, AVSIM and others and cannot find the reason. Whatever I try I end up with the same issue.
Many thanks,
Kevin.
<Option Key="GoFlight.Activated.MCP" Value="True" />
so that Value="False"
Do you mean that I CAN change the line?
Kevin.
I assumed you meant that I could change it, so I did. You're a GENIUS! It seems to work (certainly on first attempt). Hopefully it won't change the config file when I reboot in future!
Thanks a million Steve! Have a great weekend!
Cheers!
Kevin.
