MCP Pro stopped working mid flight.
All going too well!
All working fine, then mid flight, the MCP Pro turned itself off, I tried to get it going again and although I had some responses from switches, they were intermittent and clearly not functioning correctly. End of flight! Please see logs attached. The only change I made prior to the flight was to run an APM Fix (to sort out Saitek radios not coming alive (see: http://www.codelegend.com/forums/viewtopic.php?f=2&t=575).
Best wishes,
Kevin.
All going too well!
Best wishes,
Kevin.
If yes to both of the above, try flying again to confirm it wasn't a one off issue.
Cheers
Kevin
Seems to be fine - I'll let you know if it changes. MCP PRO was set to a state of AV_ENABLED. I'm assuming that the utility I ran to try and fix SPADNext (AGAIN!!!!!), probably altered the state.
Kevin.
