fsx boot error with the new version 2.0.1131.0 gofligth interface for FSX)
I have the following error can someone help me with the version xxxx29 not happening to me
view the message in the attached file
I would try removing the lines:
and add them above the following line so that it loads last:
</SimBase.Document>
If that doesn't work, remove all the add-on entries from dll.xml except the Goflight Interface Tool and try again. If that works, start adding back the add-on entries one at a time until you find what its clashing with it.
