GIT conflict with IXEG 737 classic
Hi every body and Dear admin,
I can not login to GIT and xplane11 since updating to new version of GIT software after getting Boot problem of my PC, now I found out that it has conflict with IXEG 737 classic airplane and Gismo of that airplane, I ask everyone to help me to solve this problem cause I am a real pilot and need this simulation indeed. Thank you for all your support.
Firouz
  • What makes you think its a Gizmo problem. I pointed out to you in a prior thread on this forum that your error message was caused by x-Plane plugins that are keeping files open that GIT needs to read. All you need to do is disable the plugins that are causing the problem.
  • Thank you for reply.But, it was working few weeks ago,after i updating GIT ,the problem happened.
    Thanx,
    Firouz
  • Regardless, another program/plugin within X-Plane is keeping open a file that is stopping GIT from working correctly. You need to track down that program/plugin and disable/stop it.
