MCP Pro lights not consistent
First off I apologize if the category is wrong. I wasnt sure which one to pick.
I run Xplane 11 on steam. IXEG 737. It is NOT the latest update released a few weeks ago. I downloaded the IXEG profile by Slayer (?)
The panel lights up like it should. BUT what i notice is that the LEDS dont always come on the GF-MCP Pro. For instance if I turn on the A/T ARM switch, on the GF-MCP Pro, it will correctly send the signal to the sim and the switch moves correctly on the sim and it's (sim) light comes on above the sim switch. But the light on the GF-MCP Pro itself is not consistent. It MAY come on...it may not. Sometimes it comes on but then when I turn it off the light stays on on the GF-MCP Pro.....if i flick on and off a few times then it will turn off. So I am confused...am I doing something wrong ?
I'm running Zibo's B737. Have had the same issue (but not with the A/T switch). The light for the FD switch sometimes doesn't come. Switch off and on again and it works. For me it's infrequent so I haven't worried about it.
The buttons are also a little problematic. I've found adjusting the settings helps. Shorten the button hold time.
Probably a question for Steve, but what are the implications if I set the button hold time to zero?
There are news for this problem that still occurs even with the latest update of GIT ?
What can be done to avoid this constant problem?
