GoFlight Interface Tool
My MCP PRO doesn't work recently with GoFlight Interface Tool . the EFIS works fine and the digits of the MCP PRO shows ------ only
I don't understand how program it corrctly.
Some times it works and I don't know why and How and some time not
Please help me
  • What aircraft is causing the issue and and what flight sim are you using?
  • I Flight FsX Steam Edition and CD version on another computer
    Windows 7 Integral Version on one computer and Family Premium in the Other
    I Flight mostly PMDG 737 GX
  • The NGX auto configures for the MCP PRO. All you need to do is load up the NGX so the cockpit is showing, then in GIT go to the MCP PRO tab, click on the dropdown to select Device 0 and then change the state from DISABLED to ENABLED. Quit GIT and then restart it and your MCP PRO should function correctly. You only need to do this once.
    If it doesn't work, make sure you are using the FSX SE version of GIT.
  • I have MCP and I downloaded your software but I only get one light green red on X Plane and red Aircraft "GIP pipe connection failed"
    Don't know what to do.
  • It sounds like the plugin is not running in X-Plane. During GIT installation, did you check the directory was correct for the plugin installation. If so please check the folder exists under plugin\resources in x-plane.
