MCP - HDG/CRS rotation speeds
Goflight MCP - XP11 - Laminar Baron B58
Rotating the MCP heading or course selector is a slow process under the FS default MCP config - especially all the way thru 180deg.
Is there a method that can be applied to manage a two step rotation speed to reduce the time spent winding the bug thru large changes ?
* Rotate fast = 10deg increments
* Rotate slow = 1deg increments
Thanks in advance,
Brett
  • Hi Bret,
    Can you check the Event Action is set to ROTATE for the clockwise and anti-clockwise events.
  • Steve - I'll follow this up once I get my system back up and running after rebuild.
    Yes, the MCP Heading event action is set to rotate for both the clockwise and anti clockwise events, but there is no ability to increase the speed of rotation, which is what I am after.
    I wondered if you could apply a bespoke event that may provide a two-step rotational speed selection for both the HDG and Nav1-Nav2 CRS selector.
    Brett
  • With the ROTATE event action, the faster you turn the rotary, the greater the change.
    If that still isn't good enough, you would need two bespoke events for the heading change which would add or subtract 10 degrees from the dataref "sim/cockpit/autopilot/heading_mag".
  • flakster , when I run into that situation and acceleration doesn't seem to work , sometimes it's just as easy to find the commands that rotate the knob left/right and use those instead of hitting the dataref directly. Then you will be using any acceleration routine that Laminar or the airplane developer put in by default without having to do anything special in GIT
  • Thank you Steve - I'll give that a try.
  • BTW. if I rapidly rotate the GF-MCP HDG bug in excess of 90deg (in either direction) from the original HDG, the GIT will (more often than not) crash .. requiring a USB disconnect/reconnect plus a GIT-RESTART to reload the MCP.
  • I'll see if I can replicate the problem.
  • A discussion on the X-Plane HDG/OBS rapid rotational speeds may be found via this thread on X-Plane.org.
    It appears that Laminar have not yet had the time to include a fix, however the coding of a simple Lua script plugin by a XP.org member (see post dated 10Jan18) may have merit - albeit not specifically designed for GoFlight equipment.
    I have not attempted to install the plugin as yet, as I am unsure how what effect it may have on the stability of GIT, but I would appreciate your thoughts before heading down that path.
    Thx Brett
  • Hi Brett,
    Are Commands being used on the rotary or is it a Bespoke Event that's updating a dataref?
  • Hi Steve - I've attached the Lua script for managing the HDG rotational speed.
    Additional Lua scripts for airspeed, altitude, elev_trim, ops and vertspeed are located in a zipped folder at the X-Plane.org link in my previous post.
    Thx Brett
    dataref("TIME", "sim/time/total_running_time_sec")
    --dataref("HDG_AP", "sim/cockpit/autopilot/heading", "writable")
    --How many degrees should the trim jump each time if your spinning fast?
    local FastDegreesHDG = 12
    local StandardDegreesHDG = 1
    --How many spins per second (or button presses per second) is considered FAST?
    local HDGFastTurnsPerSecond = 3
    local TresholdTime=0.4
    --You shouldnt need to change anything below-----------------------------------
    --HDGTurnTimes is used to store times since each turn
    HDGTurnTimes = {}
    HDGNumberUpTurns = 1
    HDGNumberDownTurns = 1
    local i = 1
    for i = 1, HDGFastTurnsPerSecond do
    HDGTurnTimes[i]=1
    end
    function HDGIncrement()
    local hdg
    hdg=get("sim/cockpit/autopilot/heading")
    local TimeNow = TIME
    HDGTurnTimes[HDGNumberUpTurns] = TimeNow
    local i = 1
    local ItsFast = 1
    if (HDGTurnTimes[i] + TresholdTime >= TimeNow) and (ItsFast == 1) then
    ItsFast = 1
    else
    ItsFast = 0
    end
    end
    HDGNumberUpTurns = HDGNumberUpTurns + 1
    if HDGNumberUpTurns > HDGFastTurnsPerSecond then
    end
    if ItsFast == 1 then
    hdg=hdg+FastDegreesHDG
    else
    hdg=hdg+StandardDegreesHDG
    end
    set("sim/cockpit/autopilot/heading",hdg % 360)
    end
    function HDGDecrement()
    local hdg
    print (hdg)
    HDGTurnTimes[HDGNumberDownTurns] = TimeNow
    local i = 1
    local ItsFast = 1
    ItsFast = 1
    else
    ItsFast = 0
    end
    end
    HDGNumberDownTurns = HDGNumberDownTurns + 1
    if HDGNumberDownTurns > HDGFastTurnsPerSecond then
    end
    hdg=hdg-FastDegreesHDG
    else
    hdg=hdg-StandardDegreesHDG
    end
    end
    create_command("FlyWithLua/HDG_UP","This command moves HDG bug up","HDGIncrement()", " ", "")
    create_command("FlyWithLua/HDG_DOWN","This command moves HDG bug down","HDGDecrement()", " ", "")
  • How have you configured the rotaries for the Laminar Baron B58 - Commands or DataRefs?
    I am using the standard GIT Baron 58 config.
    Brett
  • So if I can locate and apply the rotary commands (as Slayer suggested above) then install the Lua script plugin, it may function without interrupting GIT ?
  • edited March 2018
    You could try it or you could create two lua scripts in GIT as follows and assign them to your heading rotary in GIT:
    Hdg Increase Lua File:
    hdg = getdref("sim/cockpit/autopilot/heading") + getlastinput()
    setdref("sim/cockpit/autopilot/heading", hdg % 360)
    Hdg Decrease Lua File:
    hdg = getdref("sim/cockpit/autopilot/heading") - getlastinput()
  • edited March 2018
    Acceleration is not working with rotate set using stock Xplane datarefs. A little bit better if I put the sliders for the MCP near zero but seems like it worked better before. Actally they may be built in commands. Hard to tell..
