GIT crashes when trying to configure any joystick axis
After enabling joysticks, going to the joystick tab, selecting a joystick (happens for all joystick devices on my system), select Configures Axes - then any operation I do (e.g. Clear Axes) causes GIT to crash.
When I open the Configure Axes window, I get the following log message for any joystick without even trying to make any changes, just opening the window:
"Axis Config Model: Property Change Error: Value cannot be null."
Any idea what is going on?
Marc
  • Attached full log file.
  • Answer ✓
    Hi Marc,
    Just tested and found the bug. I'm surprised it hasn't been reported sooner. The fix will be available in the next release - hopefully this weekend.
  • That was quick :-) Thanks a lot.
  • Answer ✓
    New version is now available that resolves this issue.
