Goflight MCP and Xplane 11
I can't seem to get the Goflight MCP working. Some of the knobs work(Heading, Course, IAS/MACH) but many of the other are not responding. I am using the X737 and imported the conf file for that aircraft
Which specific 737 are you referring to?
12:53:42 GIP - Message Processor Exception: The process cannot access the file 'F:\X-Plane 11\Aircraft\x737-800\DREDataRefs.txt' because it is being used by another process.
Re-run the import wizard. You will still see those errors but it should have fixed the problem.
3:10:44 Calling Aircraft Changed
13:10:44 Aircraft Changed
13:10:45 XPlane: Event Received: Sim State 1
13:10:47 Synchronising Switches & Selectors Complete
Just one other question. When I push the ALT Hold button on my MCP it doesn't stay lighted but on my PFD it shows the ALT Hold active. Is this a bug?
