Install MCP-PRO with PMDG 737 ngx
Hi Steve, This is a follow up from the post I made on the Go Flight forum found here..http://goflight.vanillaforums.com/discussion/593/install-mcp-pro-with-pmdg-737-ngx#latest
Since my last post on the above, I have now installed FSUIPC. The error you will see on the last post and photo has now dissapeared. The MCP still does not work with the same issue.. I do however now get a yellow light on the interface under Simconnect / FSX with the following error in the log. Anny suggestions please? Your help is greatly appreciated!
20:30:53 GoFlight Connection Started
20:30:53 SimConnect Message Processing Started
20:30:53 SimConnect Connection Started
20:30:53 Aircraft Connection Starting.....
20:30:53 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
20:30:53 SimConnect: Event Received: SIM, 1
20:30:53 SimConnect: Event Received: PAUSE, 0
20:30:54 Aircraft Connection Started
20:30:54 Simconnect Version: 10.0.61259.0
20:30:54 Synchronising Switches & Selectors .....
20:30:54 SimConnect: Exception Received: ERROR
20:30:54 SimConnect: Exception Received: UNRECOGNIZED_ID
20:30:55 SimConnect: Exception Received: ERROR
20:30:57 Synchronising Switches & Selectors Complete
«1
  • edited July 2014
    can you check via Windows Update you have all the .NET framework updates.
  • edited November -1
    Hi Steve, Just checked windows update and I have no outstanding updates so asume it is up to date?
    Netframework 4.5.1 is installed
    Do the displays stay at zero or simply have incorrect values?
    All incorrect values, just like on the photo I uploaded on the go flight forum.
    Cheers for your help.
    Rgds
    Leon
    OK, it sounds like something is interfering with the MCP. Can you make sure GFConfig has the MCP set to compatiable add-on. Disable LINDA if you are using it. Quit the Goflight driver software (the blue icon in the notification area) and make sure you have no LUA scripts running via FSUIPC.
    I have had one user who installed FSX in program files(x86) without admin security rights. The NGX did not install correctly and caused the same problem.
    GF Config is set to compatiable add-ons
    FSX is on a dedicated HD and installed with admin rights. I start FSX with admin rights on every fresh start.
    I can confirm I do not use LINDA
    I only have the free version of FSUIPC and dont have any scripts running through it.
    Hope this helps?
    Can you set the Cmd and Write sliders on the MCP tab to 0.
    ok done. Still the same.
    Are you using the latest Goflight drivers?
    This is the one I have installed
    GFConfigSetup_2_24 Build 3
    http://www.goflightinc.com/pages/support
    To be honest, I've run out of ideas. I'll have to chew on it and come back to you.
    No problem, cheers for your help!! Much appreciated!
    hello
    i have the same error would you find the solution please
    regards
    i have same error i push the alt hld botton altitud in the mcp pro remain zero and the fsx zero too but when a i have to change altitud my cmp heading remain zero and fsx go any altitud i put it. why same with other course, ias, heading
    Hi John,
    Since a few of you have all suddenly appeared with this error, I'm going to check the software over the weekend as I suspect a Windows update has broken something. I'll come back to you within the next 24 hrs.
    Thank you so much! I still have the same issue so any help is greatly appreciated!
    Rgds
    Leon
    Thks will really be happy will waiting
  • edited August 2014
    OK, I have just updated my old FSX system with 48 updates, uninstalled and reinstalled the Goflight drivers and GIT and everything worked fine.
    So we need to troubleshoot. I need the following:
    - Confirm you are using the correct GIT version made for FSX and not the one for P3D
    - Confirm that you have not replaced uiautomationcore.dll in the Windows directory
    - Confirm you have .NET framework 4 installed.
    - Confirm you have the latest Goflight drivers installed.
    - Confirm all FSX add-ons that run externally from FSX and use Simconnect work OK.
    - Confirm you have added the DLL file in the XML file as per the installation instructions.
    - Confirm that you are not triggering the known bug in the PMDG SDK where updates stop being sent (details in the user guide).
    - Confirm you installed FSX, NGX, Goflight drivers and GIT with Administrator privileges.
    - Confirm you are running the above with administrator privileges.
    If all the above are OK.
    - Reinstall .NET framework 4. You can get it from Microsoft Downloads. You will have to install the latest version if you are running a .NET version above 4.
    - Has GIT ever worked on your PC?
    - Provide operating system details and the GIT error log.
    - Provide the 737NGX_Options.ini file. E.g from H:\FS X\PMDG\PMDG 737 NGX
    V2.24 BUIT 3 VERSION
    DONT SEE IT IN FSX DIRECTORY BUT IN WINDOWS SYSTEM 32
    YES INSTALLED YESTERDAY UP DATE
    YES GOFLIGHT PMDG INTERFACE 1-2-14-0
    GOFLIGHT INTERFACE TOOL 2.0.1131-0 DOWMLOAD YESTERDAY
    THIS PARTS DONT UNDESTRAND
    NEVER ADDED ANY DLL IN XML JUST RUN TO INSTALL THE SOFTWARE AS REQUEST !!!!!!
    YES INSTALLEDS AS ADMINISTRATOR
    YES
    14:17:39 GoFlight Connection Starting.....
    14:17:39 SimConnect Connection Starting.....
    14:17:40 GoFlight Connection Started
    14:18:16 SimConnect Message Processing Started
    14:18:16 SimConnect Connection Started
    14:18:16 Aircraft Connection Starting.....
    14:18:20 SimConnect: Event Received: Start
    14:18:20 PMDG SDK option is OK in FSX
    14:18:20 SimConnect: Event Received: Aircraft Type Changed
    14:18:20 SimConnect: Event Received: SIM, 0
    14:18:20 SimConnect: Event Received: PAUSE, 0
    14:18:20 GoFlight Connection Starting.....
    14:18:20 SimConnect Message Processing Finished
    14:18:20 SimConnect Connection Starting.....
    14:18:21 SimConnect Message Processing Started
    14:18:21 GoFlight Connection Started
    14:18:22 SimConnect Connection Started
    14:18:22 Aircraft Connection Starting.....
    14:18:22 SimConnect: Event Received: Start
    14:18:22 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    14:18:22 SimConnect: Event Received: SIM, 0
    14:18:22 SimConnect: Event Received: PAUSE, 1
    14:18:23 Aircraft Connection Started
    14:18:23 Simconnect Version: 10.0.61259.0
    14:18:23 Synchronising Switches & Selectors .....
    14:18:23 Synchronising Switches & Selectors: Waiting for Simconnect .....
    14:18:23 SimConnect: Exception Received: EVENT_ID_DUPLICATE
    14:18:42 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    14:19:03 SimConnect: Event Received: SIMSTART, 0
    14:19:03 SimConnect: Event Received: SIM, 1
    14:19:04 SimConnect: Exception Received: ERROR
    14:19:05 SimConnect: Exception Received: ERROR
    14:19:06 SimConnect: Exception Received: ERROR
    14:19:07 SimConnect: Exception Received: ERROR
    14:19:08 SimConnect: Exception Received: ERROR
    14:19:09 SimConnect: Exception Received: ERROR
    14:19:10 SimConnect: Exception Received: ERROR
    14:19:11 SimConnect: Exception Received: ERROR
    14:19:12 SimConnect: Exception Received: ERROR
    14:19:13 SimConnect: Exception Received: ERROR
    14:19:14 SimConnect: Exception Received: ERROR
    14:19:15 SimConnect: Exception Received: ERROR
    14:19:16 SimConnect: Exception Received: ERROR
    14:19:17 SimConnect: Exception Received: ERROR
    14:19:18 SimConnect: Exception Received: ERROR
    14:19:19 SimConnect: Exception Received: ERROR
    14:19:20 SimConnect: Exception Received: ERROR
    14:19:21 SimConnect: Exception Received: ERROR
    14:19:22 SimConnect: Exception Received: ERROR
    14:19:23 SimConnect: Exception Received: ERROR
    14:19:24 SimConnect: Exception Received: ERROR
    14:19:25 SimConnect: Exception Received: ERROR
    14:19:26 SimConnect: Exception Received: ERROR
    14:19:27 SimConnect: Exception Received: ERROR
    14:19:28 SimConnect: Exception Received: ERROR
    14:19:29 SimConnect: Exception Received: ERROR
    14:19:30 SimConnect: Exception Received: ERROR
    14:19:31 SimConnect: Exception Received: ERROR
    14:19:33 Synchronising Switches & Selectors Complete
    14:19:40 SimConnect Message Processing Finished
    14:19:40 GoFlight Connection Starting.....
    14:19:41 SimConnect Connection Starting.....
    14:19:41 GoFlight Connection Started
    14:19:42 SimConnect Message Processing Started
    14:19:42 SimConnect Connection Started
    14:19:42 Aircraft Connection Starting.....
    14:19:42 PMDG SDK option is OK in FSX
    14:19:42 SimConnect: Event Received: Aircraft Type Changed
    14:19:42 SimConnect: Event Received: SIM, 1
    14:19:42 SimConnect: Event Received: PAUSE, 0
    14:19:42 SimConnect Message Processing Finished
    14:19:42 GoFlight Connection Starting.....
    14:19:43 SimConnect Connection Starting.....
    14:19:44 GoFlight Connection Started
    14:19:44 SimConnect Message Processing Started
    14:19:44 SimConnect Connection Started
    14:19:44 Aircraft Connection Starting.....
    14:19:44 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    14:19:44 SimConnect: Event Received: SIM, 1
    14:19:44 SimConnect: Event Received: PAUSE, 0
    14:19:45 Aircraft Connection Started
    14:19:45 Simconnect Version: 10.0.61259.0
    14:19:45 Synchronising Switches & Selectors .....
    14:19:45 SimConnect: Exception Received: EVENT_ID_DUPLICATE
    14:19:45 SimConnect: Exception Received: ERROR
    14:19:46 SimConnect: Exception Received: ERROR
    14:19:47 SimConnect: Exception Received: ERROR
    14:19:48 SimConnect: Exception Received: ERROR
    14:19:49 SimConnect: Exception Received: ERROR
    14:19:50 SimConnect: Exception Received: ERROR
    14:19:51 SimConnect: Exception Received: ERROR
    14:19:52 SimConnect: Exception Received: ERROR
    14:19:53 SimConnect: Exception Received: ERROR
    14:19:54 SimConnect: Exception Received: ERROR
    14:19:55 SimConnect: Exception Received: ERROR
    14:19:56 SimConnect: Exception Received: ERROR
    14:19:57 SimConnect: Exception Received: ERROR
    14:19:58 SimConnect: Exception Received: ERROR
    14:19:59 SimConnect: Exception Received: ERROR
    14:20:00 SimConnect: Exception Received: ERROR
    14:20:01 SimConnect: Exception Received: ERROR
    14:20:02 SimConnect: Exception Received: ERROR
    14:20:03 SimConnect: Exception Received: ERROR
    14:20:04 SimConnect: Exception Received: ERROR
    14:20:05 SimConnect: Exception Received: ERROR
    14:20:06 SimConnect: Exception Received: ERROR
    14:20:07 SimConnect: Exception Received: ERROR
    14:20:08 SimConnect: Exception Received: ERROR
    14:20:09 SimConnect: Exception Received: ERROR
    14:20:10 SimConnect: Exception Received: ERROR
    14:20:11 SimConnect: Exception Received: ERROR
    14:20:12 SimConnect: Exception Received: ERROR
    14:20:13 SimConnect: Exception Received: ERROR
    14:20:15 Synchronising Switches & Selectors Complete
    Shortcuts]
    FD L=70, 0, 1, 0
    FD R=0, 0, 0, 0
    A/T ARM=82, 1, 0, 0
    TO/GA SWITCH=71, 1, 1, 0
    CMD A=90, 0, 0, 0
    CMD B=0, 0, 0, 0
    CWS A=0, 0, 0, 0
    CWS B=0, 0, 0, 0
    N1 SWITCH=0, 0, 0, 0
    SPEED SWITCH=82, 0, 1, 0
    VNAV SWITCH=0, 0, 0, 0
    LVL CHG SWITCH=0, 0, 0, 0
    HDG SEL SWITCH=72, 0, 1, 0
    LNAV SWITCH=78, 0, 1, 0
    VOR LOC SWITCH=79, 0, 1, 0
    APP SWITCH=65, 0, 1, 0
    ALT HOLD SWITCH=90, 0, 1, 0
    V/S SWITCH=0, 0, 0, 0
    COURSE SEL DEC (CAPT)=0, 0, 0, 0
    COURSE SEL INC (CAPT)=0, 0, 0, 0
    SPEED SELECTOR DEC=0, 0, 0, 0
    SPEED SELECTOR INC=0, 0, 0, 0
    BANK SELECTOR DEC=0, 0, 0, 0
    BANK SELECTOR INC=0, 0, 0, 0
    HEADING SELECTOR DEC=0, 0, 0, 0
    HEADING SELECTOR INC=0, 0, 0, 0
    ALTITUDE SELECTOR DEC=0, 0, 0, 0
    ALTITUDE SELECTOR INC=0, 0, 0, 0
    V/S SELECTOR DEC=0, 0, 0, 0
    V/S SELECTOR INC=0, 0, 0, 0
    COURSE SEL DEC (FO)=0, 0, 0, 0
    COURSE SEL INC (FO)=0, 0, 0, 0
    C/O SWITCH=77, 0, 1, 0
    SPD INTV SWITCH=0, 0, 0, 0
    ALT INTV SWITCH=0, 0, 0, 0
    DISENGAGE BAR=0, 0, 0, 0
    A/P DISENGAGE SWITCH=0, 0, 0, 0
    A/T DISENGAGE SWITCH=0, 0, 0, 0
    GEAR LEVER UP/DOWN=71, 0, 0, 0
    GEAR LEVER OFF=71, 1, 0, 0
    GEAR LEVER UNLOCK=71, 0, 1, 0
    AUTOBRAKE DEC=0, 0, 0, 0
    AUTOBRAKE INC=0, 0, 0, 0
    ENG SWITCH=0, 0, 0, 0
    SYS SWITCH=0, 0, 0, 0
    N1 SET SEL DEC=0, 0, 0, 0
    N1 SET SEL INC=0, 0, 0, 0
    N1 SET CONTROL DEC=0, 0, 0, 0
    N1 SET CONTROL INC=0, 0, 0, 0
    SPD REF SEL DEC=0, 0, 0, 0
    SPD REF SEL INC=0, 0, 0, 0
    SPD REF CONTROL DEC=0, 0, 0, 0
    SPD REF CONTROL INC=0, 0, 0, 0
    CHR=0, 0, 0, 0
    ET=0, 0, 0, 0
    RESET=0, 0, 0, 0
    TIME/DATE=0, 0, 0, 0
    SPOILERS DOWN=0, 0, 0, 0
    SPOILERS ARM/DISARM=0, 0, 0, 0
    SPOILERS 50 PCT=0, 0, 0, 0
    SPOILERS FLT DET=0, 0, 0, 0
    SPOILERS UP=0, 0, 0, 0
    ENG 1 IDLE=113, 1, 1, 0
    ENG 1 CUTOFF=112, 1, 1, 0
    ENG 2 IDLE=115, 1, 1, 0
    ENG 2 CUTOFF=114, 1, 1, 0
    ENTRY DOOR FWD L=69, 1, 0, 0
    ENTRY DOOR FWD R=0, 0, 0, 0
    ENTRY DOOR AFT L=0, 0, 0, 0
    ENTRY DOOR AFT R=0, 0, 0, 0
    OVERWING EXIT L=0, 0, 0, 0
    OVERWING EXIT R=0, 0, 0, 0
    CARGO DOOR FWD=0, 0, 0, 0
    CARGO DOOR AFT=0, 0, 0, 0
    EQUIPMENT HATCH=0, 0, 0, 0
    AIRSTAIR=0, 0, 0, 0
    MINS DEC=0, 0, 0, 0
    MINS INC=0, 0, 0, 0
    MINS RADIO/BARO=0, 0, 0, 0
    MINS RESET=0, 0, 0, 0
    VOR/ADF SEL L=0, 0, 0, 0
    VOR/ADF SEL R=0, 0, 0, 0
    MODE DEC=0, 0, 0, 0
    MODE INC=0, 0, 0, 0
    MODE CTR=0, 0, 0, 0
    RANGE DEC=0, 0, 0, 0
    RANGE INC=0, 0, 0, 0
    TFC SWITCH=0, 0, 0, 0
    FPV SWITCH=0, 0, 0, 0
    MTRS SWITCH=0, 0, 0, 0
    BARO DEC=0, 0, 0, 0
    BARO INC=0, 0, 0, 0
    BARO IN/HPA=0, 0, 0, 0
    BARO STD=0, 0, 0, 0
    WXR SWITCH=0, 0, 0, 0
    STA SWITCH=0, 0, 0, 0
    WPT SWITCH=0, 0, 0, 0
    ARPT SWITCH=0, 0, 0, 0
    DATA SWITCH=0, 0, 0, 0
    POS SWITCH=0, 0, 0, 0
    TERR SWITCH=0, 0, 0, 0
    LANDING LIGHTS=76, 0, 1, 0
    TURNOFF LIGHTS=0, 0, 0, 0
    TAXI LIGHTS=0, 0, 0, 0
    LOGO LIGHTS=0, 0, 0, 0
    POSITION LIGHTS=0, 0, 0, 0
    ANTI COLLISION LIGHTS=0, 0, 0, 0
    WING LIGHTS=0, 0, 0, 0
    WHEEL WELL LIGHTS=0, 0, 0, 0
    COMBINER STOW/UNSTOW=0, 0, 0, 0
    MODE SWITCH=0, 0, 0, 0
    STBY SWITCH=0, 0, 0, 0
    CLR SWITCH=0, 0, 0, 0
    COCKPIT LIGHTS TOGGLE=76, 1, 0, 0
    CAPT PANEL LIGHT=0, 0, 0, 0
    CAPT FLOOD LIGHT=0, 0, 0, 0
    AFDS FLOOD LIGHT=0, 0, 0, 0
    FO PANEL LIGHT=0, 0, 0, 0
    OVERHEAD PANEL LIGHT=0, 0, 0, 0
    CIRCUIT BREAKER LIGHT=0, 0, 0, 0
    DOME LIGHT=0, 0, 0, 0
    PEDESTAL PANEL LIGHT=0, 0, 0, 0
    PEDESTAL FLOOD LIGHT=0, 0, 0, 0
    FIRE WARN=0, 0, 0, 0
    MASTER CAUTION=0, 0, 0, 0
    SYSTEM ANNUN PANEL=0, 0, 0, 0
    A/P P-RST=0, 0, 0, 0
    A/T P-RST=0, 0, 0, 0
    FMC P-RST=0, 0, 0, 0
    BELOW G/S INHIB=0, 0, 0, 0
    737NGX_Options
    [IRS.0]
    LastPosValid=0
    [IRS.1]
    LastPosValid=0
    [SDK]
    EnableDataBroadcast=1
    Hi John,
    V2.24 BUIT 3 VERSION is the Goflight drivers. Are you using the Goflight PMDG Interface or the Goflight Interface Tool (known as GIT). If you are using GIT, there are two versions - 1 for FSX and 1 for P3D. You need to make sure you use the right one.
    If you are using GIT it needs a DLL file loaded. Instructions are in the on-line manual on this website.
    Has GIT/PMDG Interface ever worked on your PC with the NGX? If so, what has recently changed?
    THIS PARTS DONT UNDESTRAND - E.g. Do you use any external weather engine such as Active Sky and is this working OK. I'm asking this question to determine if your Simconnect installation is OK.
    Are you using FSX or P3D?
    What version of Windows are you using?
    YES
    GoFlight Interface Tool Dropbox Web (2.0.1131.0 for FSX)
    GoFlight PMDG Interface FOT fsx Dropbox Web ver 1.2.14.0
    1 for
    link:GFConfigSetup_2_24 Build 3
    FROM WHERE CAN GET THIS FILE DLL AND WHERE IS THE CORRECT PLACE TO PUT IT
    JUST INSTALLED 7 DAYS AGO THOSE O3 SOFTWARES
    NOT USUING ACTIVE SKY HOW DO I KNOW MY SIMMCONNECT INSTALLATION IS OK
    I USING FSX ACELERATION SP2
    WINDOWS 7 ULTIMATE 64BIT
    SORRY MY ENGLISH IAM SPANISH
    JOHN
    You said you are using the Goflight PMDG Interface so you don't need the DLL.
    I'm assuming you have Spanish as the language in Windows. Could you try setting the Windows language to English via the Control Panel and rebooting? I'm wondering if the data is being transmitted in the incorrect format.
    just did everything you told me and still the same like the Windows language to English via the Control Panel and rebooting?
    and still have same error.
    17:00:28 GoFlight Connection Starting.....
    17:00:28 SimConnect Connection Starting.....
    17:00:29 GoFlight Connection Started
    17:00:29 SimConnect Message Processing Started
    17:00:29 SimConnect Connection Started
    17:00:29 Aircraft Connection Starting.....
    17:00:29 PMDG SDK option is OK in FSX
    17:00:29 SimConnect: Event Received: Aircraft Type Changed
    17:00:29 SimConnect: Event Received: SIM, 0
    17:00:29 SimConnect: Event Received: PAUSE, 1
    17:00:29 GoFlight Connection Starting.....
    17:00:29 SimConnect Message Processing Finished
    17:00:30 SimConnect Connection Starting.....
    17:00:31 GoFlight Connection Started
    17:00:31 SimConnect Message Processing Started
    17:00:31 SimConnect Connection Started
    17:00:31 Aircraft Connection Starting.....
    17:00:31 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    17:00:31 SimConnect: Event Received: SIM, 0
    17:00:31 SimConnect: Event Received: PAUSE, 1
    17:00:32 SimConnect: Exception Received: EVENT_ID_DUPLICATE
    17:00:32 Aircraft Connection Started
    17:00:32 Simconnect Version: 10.0.61259.0
    17:00:32 Synchronising Switches & Selectors .....
    17:00:32 Synchronising Switches & Selectors: Waiting for Simconnect .....
    17:00:44 SimConnect: Event Received: SIMSTART, 0
    17:00:44 SimConnect: Event Received: SIM, 1
    17:00:45 SimConnect: Exception Received: ERROR
    17:00:46 SimConnect: Exception Received: ERROR
    17:00:47 SimConnect: Exception Received: ERROR
    17:00:48 SimConnect: Exception Received: ERROR
    17:00:49 SimConnect: Exception Received: ERROR
    17:00:50 SimConnect: Exception Received: ERROR
    17:00:51 SimConnect: Exception Received: ERROR
    17:00:52 SimConnect: Exception Received: ERROR
    17:00:53 SimConnect: Exception Received: ERROR
    17:00:54 SimConnect: Exception Received: ERROR
    17:00:55 SimConnect: Exception Received: ERROR
    17:00:56 SimConnect: Exception Received: ERROR
    17:00:57 SimConnect: Exception Received: ERROR
    17:00:58 SimConnect: Exception Received: ERROR
    17:00:59 SimConnect: Exception Received: ERROR
    17:01:00 SimConnect: Exception Received: ERROR
    17:01:01 SimConnect: Exception Received: ERROR
    17:01:02 SimConnect: Exception Received: ERROR
    17:01:03 SimConnect: Exception Received: ERROR
    17:01:04 SimConnect: Exception Received: ERROR
    17:01:05 SimConnect: Exception Received: ERROR
    17:01:06 SimConnect: Exception Received: ERROR
    17:01:07 SimConnect: Exception Received: ERROR
    17:01:08 SimConnect: Exception Received: ERROR
    17:01:09 SimConnect: Exception Received: ERROR
    17:01:10 SimConnect: Exception Received: ERROR
    17:01:11 SimConnect: Exception Received: ERROR
    17:01:12 SimConnect: Exception Received: ERROR
    17:01:14 Synchronising Switches & Selectors Complete
    sorry about this probelm how do i know if i have this in my fsx
    SimConnect SDK
    http://msdn.microsoft.com/en-us/library/cc526983.aspx
    Hi John,
    You are flying the PMDG NGX 737 and not the PMDG 777?
    the PMDG NGX 737
