mpc pro settings don't match pmdg 737 p3d aircraft
pmdg 737 800 p3d
Are you using the correct version of GIT for your flight sim version?
Are you running the very latest version of the 737?
Are there any errors in the Log tab?
Do you have other software that is updating the displays such as an FSUIPC LUA script?
Do you do not have all the latest .NET Framework 4 updates?
If I set for anything other than FS Default it will not work at all
New programs
No errors in the log tab
No other software updating
Installed latest .NET Framework updates
The digits on my mcp pro progressively worsen no matter how quickly the knob is turned. The numbers between the mcp pro and what I see on the monitor will start out close in range. However, when I turn the knob further the range between the mcp pro and what I see on the monitor, are greater in value.
If the MCP does not then work, make sure you have enabled support for it in the GIT MCP tab (pick the device, then set to ENABLED). If it is still not working see the entry called "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes)" in the FAQ here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/41-faq/70-faq.html
