git doesnt recognize pmdg aircraft..
Please can you help me my git doesn recognize that I use a pmdg aircraft on aircraft sdection instead of a pmdg aircraft it says ed martin… I attached a picture of my problem..,.
1) Rename Documents\GoFlight Interface Tool so GIT starts with no config.
2) Uninstall/Reinstall GIT
3) Uninstall/Reinstall the PMDG aircraft
You could try rolling back the Windows Update and if that doesn't help, its a reinstall of P3D.
Steev
13:45:02 SimConnect Connection Starting.....
13:45:03 SimConnect Message Processing Started
13:45:03 GoFlight Connection Started
13:45:03 SimConnect Connection Started
13:45:03 Aircraft Connection Starting.....
13:45:03 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
13:45:03 SimConnect: Event Received: SIM, 1
13:45:03 SimConnect: Event Received: PAUSE, 0
13:45:05 WinSock: Connected To localhost On Port 27015!
13:45:05 LUA Processor: Started!
13:45:07 FSUIPC: Connection Failed: Hedef makine etkin olarak reddettiğinden bağlantı kurulamadı 127.0.0.1:8385
13:45:07 Aircraft Connection Started
13:45:07 Simconnect Version: 4.0.0.0
13:45:07 Aircraft FullName: ed Martin
13:45:07 Synchronising Switches & Selectors .....
13:45:07 LvarNamesUpdated!
13:45:07 Creating Bespoke Vars
13:45:07 Bespoke Vars Created
13:45:07 Importing Bespoke Variables
13:45:07 Bespoke Vars Assigned, Importing Bespoke Events
13:45:07 Bespoke Events Temp Imported
13:45:07 Bespoke Events Imported
13:45:07 Loading Aircraft Settings
13:45:07 GetXMLConfigData
13:45:07 GotXMLConfigData
13:45:07 Loading Power
13:45:07 Loading MCPPRO
13:45:07 Loading EFIS
13:45:07 Loading P8
13:45:07 Loading T8
13:45:07 Loading RP48
13:45:07 Loading MESM
13:45:07 Loading WP6
13:45:07 Loading LGT
13:45:07 Loading LGT II
13:45:07 Loading GF46
13:45:07 Loading GF45
13:45:07 Loading TQ6
13:45:07 Loading DIO
13:45:07 Loading GF166
13:45:07 Loading SECM
13:45:07 Loading Joysticks
13:45:07 Clearing Displays
13:45:07 Reset Data
13:45:07 Aircraft Settings Loaded
13:45:07 Calling Aircraft Changed
13:45:08 Aircraft Changed
13:45:08 LvarNamesUpdated!
13:45:08 Creating Bespoke Vars
13:45:08 Bespoke Vars Created
13:45:08 Importing Bespoke Variables
13:45:08 Bespoke Vars Assigned, Importing Bespoke Events
13:45:08 Bespoke Events Temp Imported
13:45:08 Bespoke Events Imported
13:45:08 Loading Aircraft Settings
13:45:08 GetXMLConfigData
13:45:08 GotXMLConfigData
13:45:08 Loading Power
13:45:08 Loading MCPPRO
13:45:08 Loading EFIS
13:45:09 Loading P8
13:45:09 Loading T8
13:45:09 Loading RP48
13:45:09 Loading MESM
13:45:09 Loading WP6
13:45:09 Loading LGT
13:45:09 Loading LGT II
13:45:09 Loading GF46
13:45:09 Loading GF45
13:45:09 Loading TQ6
13:45:09 Loading DIO
13:45:09 Loading GF166
13:45:09 Loading SECM
13:45:09 Loading Joysticks
13:45:09 Clearing Displays
13:45:09 Reset Data
13:45:09 Aircraft Settings Loaded
13:45:09 Calling Aircraft Changed
13:45:09 Aircraft Changed
13:45:10 Synchronising Switches & Selectors Complete
Do you have any other software that can display the aircraft name via Simconnect?
It won't be a c++ issue, but it could be a problem with .NET framework. It may be worth uninstalling .NET framework and then reinstalling. You will need to do this via Control Panel, Programs and Features and then Turn Windows features on or off.
In a few weeks time, the update should have been rolled out to all customers. I can then determine if the update is causing a problem with GIT or its specific to your setup.
02:40:03 GoFlight Connection Starting.....
02:40:03 SimConnect Connection Starting.....
02:40:04 SimConnect Message Processing Started
02:40:04 GoFlight Connection Started
02:40:04 SimConnect Connection Started
02:40:04 Aircraft Connection Starting.....
02:40:04 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
02:40:04 SimConnect: Event Received: SIM, 0
02:40:04 SimConnect: Event Received: PAUSE, 0
02:40:06 WinSock: Connected To localhost On Port 27015!
02:40:06 LUA Processor: Started!
02:40:08 FSUIPC: Connection Failed: Hedef makine etkin olarak reddettiğinden bağlantı kurulamadı 127.0.0.1:8385
02:40:08 Aircraft Connection Started
02:40:08 Simconnect Version: 4.0.0.0
02:40:08 Aircraft FullName: ed Martin
02:40:08 Synchronising Switches & Selectors .....
02:40:08 Synchronising Switches & Selectors: Waiting for SimConnect .....
02:40:13 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
02:40:51 SimConnect: Event Received: SIMSTART, 0
02:40:51 SimConnect: Event Received: SIM, 1
02:40:56 LvarNamesUpdated!
02:40:56 Creating Bespoke Vars
02:40:56 Bespoke Vars Created
02:40:56 Importing Bespoke Variables
02:40:56 Bespoke Vars Assigned, Importing Bespoke Events
02:40:56 Bespoke Events Temp Imported
02:40:56 Bespoke Events Imported
02:40:56 Loading Aircraft Settings
02:40:56 GetXMLConfigData
02:40:56 GotXMLConfigData
02:40:56 Loading Power
02:40:56 Loading MCPPRO
02:40:56 Loading EFIS
02:40:56 Loading P8
02:40:56 Loading T8
02:40:56 Loading RP48
02:40:56 Loading MESM
02:40:56 Loading WP6
02:40:56 Loading LGT
02:40:56 Loading LGT II
02:40:56 Loading GF46
02:40:56 Loading GF45
02:40:56 Loading TQ6
02:40:56 Loading DIO
02:40:56 Loading GF166
02:40:56 Loading SECM
02:40:56 Loading Joysticks
02:40:56 Clearing Displays
02:40:56 Reset Data
02:40:56 Aircraft Settings Loaded
02:40:56 Calling Aircraft Changed
02:40:56 Aircraft Changed
02:40:56 Loading P8
02:40:56 Loading T8
02:40:56 Reset Data
02:40:57 Aircraft Changed
02:40:59 Synchronising Switches & Selectors Complete
We have tried all the obvious things. I can only think that something has got horribly corrupt in your system, but tracking that down is next to impossible. I can only recommend a system rebuild at this point.
"That isn't an FSUIPC log, but one produced to allow GoFlight support (or those who made the software you are using) to help. Possibly it is checking for a different version of FSUIPC, or is trying to connect before FSUIPC's interface is established."
Something in Windows or P3D got corrupted during your Windows Update so DOUBLE CHECK YOU HAVE ACTUALLY DONE:
If the above does not work, we have tried all the obvious stuff with no success. I can only suggest a rollback of your Windows update. If that doesn't work or you cannot do it, uninstall and reinstall P3D and associated software and if that doesn't work its time to reset Windows 10 and start reinstalling your software.
https://www.avsim.com/forums/topic/536982-why-has-microsoft-done-this-to-me-is-it-the-update-that-made-it-this-way/
no field package.preload['socket']socket
no file 'D:\Lockheed Martin\Prepar3D v4\modules\socket.lua'
no file 'D:\Lockheed Martin\Prepar3D v4\modules\socket\init.lua'
no file 'D:\Lockheed Martin\Prepar3D v4\modules\lua\socket.lua'
no file 'D:\Lockheed Martin\Prepar3D v4\modules\lua\socket\init.lua'
no file 'D:\Lockheed Martin\Prepar3D v4\modules\lua\socket.dll'
no file 'D:\Lockheed Martin\Prepar3D v4\modules\lua\loadall.dll'
"You are using some package with plug-ins for FSUIPC which is evidently dependent upon the socket package, including "socket.dll " or "socket.lua". Unlike FSUIPC4, the 64-bit version of FSUIPC doesn't include any Socket facilities because there's no 64-bit builds available which are compatible with the rest of the built-in Lua facilities. Folks who need Lua sockets find and install the 64-bit package for this themselves. Have a search for solutions in the forum or elsewhere.
What I don't understand is why on Earth the GoFlight interface tool is trying to use any Lua plug-ins in the first place! And especially not sockets, which are generally used for communicating with the Internet or with other PCs on your local network.
You do really need to seek Goflight suppot on this.
Pete"
The PMDG aircraft does not use Lua at all.
